-   -   Would a VX engine d15z fit into a 94+ integra? (https://www.fuelly.com/forums/f8/would-a-vx-engine-d15z-fit-into-a-94-integra-9196.html)
xiongthao 06-29-2008 01:53 PM
Hi, I'm new to the website. I'm still young but I'm very interested in fuel economy cars. I was just wondering if I am able to put a d15z into an 94+ INtegra? I would highly appreciated if anyone out there would be able to give me some tips on this. Thank you.
GasSavers_BIBI 06-29-2008 02:07 PM
A civic vx weight 2100 pounds and a Integra weight 2500 pounds and more, so the idea is not good, i would think...
xiongthao 06-29-2008 02:17 PM
thats true...but would it be possible to put a d15z into other civic cars for example 92-95 coupes or 96-00 coupes? I heard that it's difficult to do a VX engine/tranny swamp into a non-civic vx model
mrmad 06-29-2008 02:28 PM
It can be done. search D series swap on team-integra.net.
The swap is much easier on the 92-95 civics cause they already have a D series in them and they are OBD1
xiongthao 06-29-2008 02:50 PM
thanks, i'll give it a try
onefastcar 06-29-2008 08:30 PM
d15z1 94 teg
I just completed this swap in my gs-R dc2. You need a p07-A00 ecu, vx motor, with wiring harness and 5 wire o2, extra ecu pins and wire, egr control solenoid. Everything will go together real easy. except for running a couple of wires from the ecu to the engine harness and 02 wires, and a wire from the ecu to the egr control solenoid and then to a sensor ground on the driver side of the car. btw no check engine lights.
(2500lbs. Rear disc, bigger front calipers, abs, sunroof, power steering, leather) vs. (2100lbs. none of that)
I can't tell you how much I'm saving in gas yet just going through my 1st 10gal.
opelgt73 06-29-2008 09:23 PM
If you're doing a d15z1 swap you should swap the trans as well, or try to get a CRX HF trans. It won't be as sporty as it was before but your MPG will jump significantly.
onefastcar 06-29-2008 10:17 PM
crx hf tranny is a cable. try vx or hx these are hydro
opelgt73 06-30-2008 04:57 AM
A hydro to cable swap can be done and it isnt as complicated as the engine swap.
