Smalest (HH-O) i have made with the best output so fat
Small Zink cell
i used a Toilet Wast joiner and 2x end caps the cell its self has been the smallest chamber yet and the electrodes filled the complete unit, (This was done on porpoises) i will explain later why, The electrode's them self are made from DIY store Zink Bolts washers and nuts. Bolt > Washer > small washer > Washer> Small washer etc etc This was done 8 times and there was 10 Big and little washers on each electrode They were then fitted Through the end caps with nylon washers for a good seal 4 on each side 5 mill away form each-other, when the cell ends were inserted the end of each electrode was also 5 mil away from each other I wired the cell up in series so that every electrode (even opposite sides wore positive to negative giving me 12 key fracturing points and the gap between the big little and next big washer, The reason i created this cell with a small amount of space for water is because i cycled it from another container this was also made from the same material but without electrodes, i decided to do this to make sure the electrodes had a clear surface area to produce and also to incorporate cooling fins to the secondary tank, this also makes it allot easier to inspect the water fill and add electrolyte, I was extremely impressed with the reactor out put and we even managed to get a 33cc mini moto engine to fire from the built up gas in the reactor but not enough to Sistine healthy running, i have heard that your meant to retard (make it later) The timing to get the best performance form the hho burn but i do not have a great understanding of engines so if there is any one here that can shed some light on that i would appreciate it SO much |
You do realize that this does not help gas mileage right? If the gas output build-up can only get a 33cc engine to fire but not run, how much do you think that gas is going to do for a 2000cc engine, or a 5000cc engine which is over 150 times larger!? The science behind this does NOT support even the possibility that an HHO-generator will increase FE at all. My only motivation for writing this is to educate people and prevent the waste of their time and money.
i can see where your coming from if you have not had a go because i didn't believe it at first, |
