-   -   D16z6 (https://www.fuelly.com/forums/f10/d16z6-8775.html)
93dagsr 06-04-2008 06:27 AM
D16z6
ok i'm about to get a pretty good deal for a motor. its the D16Z6 for $200 i wanted to buy it for a direct replacement on mine (knocking) but started to think about how can i modify my knocking motor into a gas sipping monster?! do i raise the compression? cam? what would i do with the bottom end? help me build my monster with your suggestions. :D
here's what i was thinking:
raise compression to about 10:1
buy a mild cam skunk stage 1 or 2
buy shorter rods, to make it a shorter stroke
and thats about it. anything else you guys would suggest?
jmaze 06-10-2008 03:12 PM
what tranny are u going to be using?
maxxgraphix 06-10-2008 07:20 PM
Chip the ECU. Dual modes, switch on the fly, econo and performance. Get a wide band O2, chipped P28 and data logging. Go for aero mods and light rims. 38mpg is possible.
93dagsr 06-11-2008 06:38 AM
my oem ex tranny with a vx 5th gear. i do highway all day pretty much every day. :thumbup:
93dagsr 06-11-2008 06:39 AM
how can i get the dual modes? would i need two ecu's? and if i got the vafc can i tune it with that and how many maps can i get on there? thanks for the help guys! :D
93dagsr 06-11-2008 06:46 AM
on my transmission will a hf fifth gear fit? or am i better off with the vx? which would you guys do?
93dagsr 06-11-2008 12:09 PM
which one would yield better fe at 60-90 mph?
samandw 06-11-2008 12:21 PM
Shorter rods will only change you rod-to-stroke ratio, not your stroke. Changing the stroke requires a different crank, not something I'd consider worthwhile.
However, with that in mind, you can lower the "effective" displacement by using a custom ground Aktinson Cycle camshaft that leaves the intake valve open after BDC. This would allow you to build the engine with a much higher mechanical compression ratio (and greater efficiency) but without risking detonation. . .ala the Prius engine that has a 13.6:1 mechanical compression ratio yet runs on regular unleaded.
DC5_Angelo 06-11-2008 04:37 PM
thats not going to do anything, they both have the same 5th gear ratio
93dagsr 06-12-2008 09:24 AM
really? i thought it had a longer ratio? i noticed that at 60 mph yesterday i was dead on at 2500 rpms.
what about the hf (crx) fifth gear i heard that will drop me to 1500 rpm @ 60 mph
