D16z6 - Fuelly Forums
Old 06-04-2008, 06:27 AM   #1
93dagsr's Avatar
D16z6
ok i'm about to get a pretty good deal for a motor. its the D16Z6 for $200 i wanted to buy it for a direct replacement on mine (knocking) but started to think about how can i modify my knocking motor into a gas sipping monster?! do i raise the compression? cam? what would i do with the bottom end? help me build my monster with your suggestions.
here's what i was thinking:
raise compression to about 10:1
buy a mild cam skunk stage 1 or 2
buy shorter rods, to make it a shorter stroke
and thats about it. anything else you guys would suggest?
https://consumerguideauto.howstuffwor...onda-civic.htm
stupid ricer... useless wings are for pinguins!
93dagsr is offline   Reply With Quote
Old 06-10-2008, 03:12 PM   #2
what tranny are u going to be using?
jmaze is offline   Reply With Quote
Old 06-10-2008, 07:20 PM   #3
Chip the ECU. Dual modes, switch on the fly, econo and performance. Get a wide band O2, chipped P28 and data logging. Go for aero mods and light rims. 38mpg is possible.
https://www.maxxgraphix.net
maxxgraphix is offline   Reply With Quote
Old 06-11-2008, 06:38 AM   #4
93dagsr's Avatar
my oem ex tranny with a vx 5th gear. i do highway all day pretty much every day.
Old 06-11-2008, 06:39 AM   #5
93dagsr's Avatar
how can i get the dual modes? would i need two ecu's? and if i got the vafc can i tune it with that and how many maps can i get on there? thanks for the help guys!
Old 06-11-2008, 06:46 AM   #6
93dagsr's Avatar
on my transmission will a hf fifth gear fit? or am i better off with the vx? which would you guys do?
Old 06-11-2008, 12:09 PM   #7
93dagsr's Avatar
which one would yield better fe at 60-90 mph?
Old 06-11-2008, 12:21 PM   #8
Shorter rods will only change you rod-to-stroke ratio, not your stroke. Changing the stroke requires a different crank, not something I'd consider worthwhile.
However, with that in mind, you can lower the "effective" displacement by using a custom ground Aktinson Cycle camshaft that leaves the intake valve open after BDC. This would allow you to build the engine with a much higher mechanical compression ratio (and greater efficiency) but without risking detonation. . .ala the Prius engine that has a 13.6:1 mechanical compression ratio yet runs on regular unleaded.
samandw is offline   Reply With Quote
Old 06-11-2008, 04:37 PM   #9
thats not going to do anything, they both have the same 5th gear ratio
DC5_Angelo is offline   Reply With Quote
Old 06-12-2008, 09:24 AM   #10
93dagsr's Avatar
really? i thought it had a longer ratio? i noticed that at 60 mph yesterday i was dead on at 2500 rpms.
what about the hf (crx) fifth gear i heard that will drop me to 1500 rpm @ 60 mph
Let the games begin! Matt Timion General Fuel Topics 4 12-11-2021 11:04 PM
Mini Cooper Owners? YakiMini Introduce Yourself - New member Welcome 0 02-17-2008 09:47 PM
Fuel filter change bowtieguy General Discussion (Off-Topic) 10 10-23-2007 08:23 PM
Free flow exhaust GasSavers_Kraig General Fuel Topics 9 08-07-2006 07:53 AM
I'm an Idiot Compaq888 General Discussion (Off-Topic) 7 06-01-2006 01:10 PM
