Competition Averages
Background: Brucepick brought-up an excellent point:
The baseline and final averages are taken by averaging the MPG value in the GasLog. In this form, a cumulative value of total miles/kilometers, vs. total gallons is not taken. A cumulative average seems to be more fair and accurate. Vote: 1) Keep the Current System 2) Implement the total/cumulative average for the Cycle This is a public vote. Please provide reasoning for your input. Thanks all! The Commish |
Cumulative. Maybe subdivide per quarter so as to see trends by season ?
I know I'm not playing, but if I understand correctly, the current situation: One tank may have only 3 gallons of "extra good behavior" then that tank would have the same weight as a 15 gallon tank of low mpg?
man just as i expected, nobody voted for the average of mpgs. good.
i thought that they were the cumulative and the cumulative |
I don't think a rules change in mid "season" is right. with the mileage that some get here they would only get 1 fill and it would get posted near end of cycle.
i dont know about you, but i commute all year round... there is no mpg season.
if anything the winter is the mpg season because i cant race and my wife(teacher) is commuting daily again. |
I was actually pondering this the other day, and meant to bring it up. But was too lazy. I think we should change to the new system as it does seem more fair, shouldn't be that hard to implement either since everything is pulled straight from the site anyhow.
"2) Implement the total/cumulative average for the Cycle" <--- this will help balance what I ask about above . |
rh77, Rick,
Guess I'm not understanding this very well. How does the proposed new rule differ from the currently posted Version 2.0 rule quoted below?? Excerpt from current Version 2.0 rules: Calculations: 6. The ?Final Percentage over EPA? is figured by the cumulative, Gaslog-sourced MPG values vs. the vehicle?s EPA FE-Combined (?Cycle-End Cumulative Percentage Over EPA?) 7. A member?s final calculation is the difference between the Baseline and Cycle-End Cumulative? or ?Improvement? (negative numbers reflect a decrease in efficiency). |
