Restricter plate
Anyone every intall a restricter plate too see if mileage improved?
I was thinking of doing it if there was proof it worked. If it does would it be better to install the plate under the TB or before it? |
It seems to me that a restrictor plate would hurt mileage due to pumping losses. Am I missing something?
Tried it -- Failed for me
I tried restricting the intake on the Integra and it just took more throttle input and no appreciable gain:
Thread. It could vary from vehicle to vehicle, but compared to old carbeurated vehicles of the past, the ECU will adjust accordingly. More importantly, intake temperture should be optimized. RH77 |
If there isnt proof you should test it and tell us the end results.
rh77....I just finished reading most of the 2 page thread on this subject. Of course I never noticed the thread to start with until I had already started this one.
However the old thread ended with no new/further results on the testing. So you say you did do it then, correct? |
Instead of a restrictor plate you could create some sort of throttle stop that would never allow you to go over 25% throttle.
I would think a restrictor plate would allow you to add more gas, but would restrict the air flow causing a rich condition. If I am wrong someone please correct me. |
A throttle stop would be the cheapest and easiest to apply.....however designing a bypass system for emergency/needed situation would require some further thought on my part.
Maybe placing a heavy spring on the floor that would normally keep you from pushing it down any further but will allow the pedal to go all the way to the floor when you press down harder???? |
Mostly Guidance
What I used to restrict the air was to plug the intake with a stopper-like device that had a small-diameter hole in the center. To get up to speed, maintain speed, or drive with load, required a considerable amount of throttle input and resulted in more fuel consumption. I don't have anything scientific or an A-B-A test, but it did free up power and consequently less throttle input. Scanguage values were used and showed that no gain was attained, and sluggish engine operation resulted. I welcome another test for maximum scientific attainability. Quote:
A spring-loaded throttle is a good idea -- one I've wanted to try. RH77 |
I have a restrictor of sorts on my car, it's in the form of an alluminum can in the exhaust (flattened with a hole in it) It's whisper silent, but really cuts down the power. I wild estimate is %50 percent less power. It has actually helped my gas mileage around town. I used to always floor it and come sliding around the corners (bad habit) With this in there, my exhuast no longer encourages me to rev it up to enjoy the sound. If it was a manual, DON"T DO IT, you can't proper pulse and glide with it. On the highway ( low load) it seems to get nearly the same gas mileage (judged by odometer/fuel gauge only)
