-   -   Correction for tire/rim sizes? (https://www.fuelly.com/forums/f2/correction-for-tire-rim-sizes-321.html)
neosin 10-07-2009 03:21 AM
I know my tires are smaller than factory and it's throwing off my miles a little bit, can we have a feature of being able to fix this? Because using scangauge2 we know the ratio to be adjusted.
can we have a feature to adjust for tire sizes?
pb 10-07-2009 03:25 AM
Sorry neosin, this is a rare case and we've decided not to add features like this that will only affect a small number of users. We have a long laundry list of features to add to the site including better graphing, better reporting, and much more.
Maybe there's a way to adjust your stats as you enter them and make a note of your changes?
techathy 10-09-2009 08:35 PM
It's easy enough to approximate the difference (your trip & odometer are hardly precision instruments them selves!). You need to know the % difference between the tyre profiles then apply that to the mileage. A quick n' dirty way is to use the tyre profiles, tread width is divided by the profile as a % then doubled & applied to the wheel diameter. If we take 195/45R15 then we get:
195*0.45*2/25.4+15=21.91" Ø
(the 25.4 is covering millimetres into inches)
Say I'm going to move to 195/40R16 tyres I have the result 22.14"
You then use the two numbers you got to get the difference in %, 1.05% in this case. So I'd add 1.05% to my mileage total.
VWJunky 10-14-2009 01:53 AM
With Scan Gauge you can adust your speed offset when you set it up. You will need GPS and then adjust so that the gauge is reading the correct MPH. I do this in my jetta as it is off just a bit. I then use all the info in Scan Gauge when filling up and inputing it here on Fuley. I am off just a few miles every tankfull with my odometer but Scan Gauge is right! LOL!
neosin 10-19-2009 05:07 AM
Thanks guys, I've installed a scangauge2 and did the setup with a GPS, it is off about 4MPH. I do not know yet if the odometer is off yet, i've heard some people on tdiclub say that the speedo is off but the odometer is spot on, I haven't checked that yet.
On my next road trip to dallas (from houston) about 400 miles, I will check odometer/GPS/Scangauge2 and tell you what the diff is. At least in my case and then I'll know what adjustments I should make.
By the way PB, love the site. Can't wait to see better graphs and other fun things.
Here's a thought how about a graph of you and your friends that would be fun...
