-   -   Check box for partial fuel-ups (https://www.fuelly.com/forums/f2/check-box-for-partial-fuel-ups-31.html)
cymor 08-08-2008 12:57 AM
Check box for partial fuel-ups. i.e. I buy 2 gallons to get me to the next town that has cheaper gas
chrisamiller 08-08-2008 01:19 AM
I don't understand why this is a problem. If you enter 2 gallons and the miles you travelled since you last refueled, your mpg will be calculated properly.
ericesque 08-08-2008 01:53 AM
and if you're driving to the next town for cheaper gas, you're losing money-- unless it's .20 cheaper/gallon, it's never worth going out of your way for gas. Even 10 gallons at .10 savings is only a dollar. Your time ought to be worth more than that.
jvconway 08-08-2008 02:05 AM
it should all even out eventually but there will be spikes in your mpg curve. say you drive 200 miles then put in 2 gallons to get you to the next town it will think you got 100mpg then you drive 2 miles to the next town and fill up you will get less than 1mpg. it should even out but won't look right.
there should be a box to check if you forget to record a fueling though.
pb 08-20-2008 07:46 AM
Partial fuel-ups are available now. And you can also mention you missed a fuel-up if you're using odometer tracking.
