Check box for partial fuel-ups - Fuelly Forums
Old 08-08-2008, 12:57 AM   #1
Check box for partial fuel-ups. i.e. I buy 2 gallons to get me to the next town that has cheaper gas
cymor is offline   Reply With Quote
Old 08-08-2008, 01:19 AM   #2
I don't understand why this is a problem. If you enter 2 gallons and the miles you travelled since you last refueled, your mpg will be calculated properly.
chrisamiller is offline   Reply With Quote
Old 08-08-2008, 01:53 AM   #3
and if you're driving to the next town for cheaper gas, you're losing money-- unless it's .20 cheaper/gallon, it's never worth going out of your way for gas. Even 10 gallons at .10 savings is only a dollar. Your time ought to be worth more than that.
ericesque is offline   Reply With Quote
Old 08-08-2008, 02:05 AM   #4
it should all even out eventually but there will be spikes in your mpg curve. say you drive 200 miles then put in 2 gallons to get you to the next town it will think you got 100mpg then you drive 2 miles to the next town and fill up you will get less than 1mpg. it should even out but won't look right.
there should be a box to check if you forget to record a fueling though.
jvconway is offline   Reply With Quote
Old 08-20-2008, 07:46 AM   #5
pb
Partial fuel-ups are available now. And you can also mention you missed a fuel-up if you're using odometer tracking.
