-   -   DIY: Wire Tuck!!! (https://www.fuelly.com/forums/f9/diy-wire-tuck-2725.html)
SVOboy 08-18-2006 09:35 PM
DIY: Wire Tuck!!!
See here: https://crxmpg.com/wiretuck.html
SVOboy 08-19-2006 07:50 PM
Updated!
Gary Palmer 08-20-2006 05:42 PM
SVOboy: Look's like a very nice job. Did you put grommet's or anything around the various hole's where you routed wire's? If you didn't, you might want to consider it, at some point. The edges of your sheet metal will, very likely, cut through the insulation on your wires and short something out, at some point in time.
SVOboy 08-20-2006 05:52 PM
I didn't just because I felt none of the edges were worth the attention. Me with my propensity for getting cut can rub my finger on them all day without anything, they seem to have been created for smoothness, or mehbe it just ended up like that.
Matt Timion 08-20-2006 05:55 PM
It might be a good idea to cut a small piece of wire loom and use that instead of a grommit.
SVOboy 08-20-2006 05:55 PM
Fine fine fine, we'll take a look tomorrow.
Gary Palmer 08-20-2006 06:13 PM
They make a material for doing them, after the fact. It's a white nylong material, with fingers on it. It's sort of like a "caterpillar" like material, where the leg's go on either side of the sheet metal and the body cover's the edge. I don't know if it's available at R.S, or not. I know I can get it at a electronic's part's store.
jolt-tsp 09-19-2006 06:41 PM
They way you described the contact point, there should be no problem. Cutting a small peice of rubber hose makes a good grommet if you care. I wouldn't worry about it though.
Looks very clean :thumbup:
GasSavers_Jack 09-20-2006 05:14 AM
Ben, Great work. I only wish I had 1/2 the time and energy that you have.
SVOboy 09-20-2006 06:31 AM
Don't get so jealous, this was done pre-summer-college-ish. I just got back from my first japanese class and I'm ready to crack, :p
