DIY: Wire Tuck!!! - Fuelly Forums
Old 08-18-2006, 09:35 PM   #1
DIY: Wire Tuck!!!
See here: http://crxmpg.com/wiretuck.html
Old 08-19-2006, 07:50 PM   #2
Updated!
Old 08-20-2006, 05:42 PM   #3
SVOboy: Look's like a very nice job. Did you put grommet's or anything around the various hole's where you routed wire's? If you didn't, you might want to consider it, at some point. The edges of your sheet metal will, very likely, cut through the insulation on your wires and short something out, at some point in time.
Old 08-20-2006, 05:52 PM   #4
I didn't just because I felt none of the edges were worth the attention. Me with my propensity for getting cut can rub my finger on them all day without anything, they seem to have been created for smoothness, or mehbe it just ended up like that.
Old 08-20-2006, 05:55 PM   #5
Matt Timion's Avatar
It might be a good idea to cut a small piece of wire loom and use that instead of a grommit.
Old 08-20-2006, 05:55 PM   #6
Fine fine fine, we'll take a look tomorrow.
Old 08-20-2006, 06:13 PM   #7
They make a material for doing them, after the fact. It's a white nylong material, with fingers on it. It's sort of like a "caterpillar" like material, where the leg's go on either side of the sheet metal and the body cover's the edge. I don't know if it's available at R.S, or not. I know I can get it at a electronic's part's store.
Old 09-19-2006, 06:41 PM   #8
They way you described the contact point, there should be no problem. Cutting a small peice of rubber hose makes a good grommet if you care. I wouldn't worry about it though.
Looks very clean
w00t, finally above the EPA rating!
jolt-tsp is offline   Reply With Quote
Old 09-20-2006, 05:14 AM   #9
GasSavers_Jack's Avatar
Ben, Great work. I only wish I had 1/2 the time and energy that you have.
See my car here:
Old 09-20-2006, 06:31 AM   #10
Don't get so jealous, this was done pre-summer-college-ish. I just got back from my first japanese class and I'm ready to crack,
More Metric Options pb Fuelly Web Support and Community News 2 08-22-2008 09:53 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
What is your favorite bulletin board software? Matt Timion General Discussion (Off-Topic) 5 03-30-2006 04:43 PM
Warm Air Intake System -- Heater coil or core? rh77 Experiments, Modifications and DIY 10 12-02-2005 12:06 PM
Convertible Honda CVCC Matt Timion General Discussion (Off-Topic) 10 11-07-2005 01:54 PM
