-   -   Some wire tuck advice please? (https://www.fuelly.com/forums/f10/some-wire-tuck-advice-please-2604.html)
SVOboy 08-02-2006 11:58 AM
For moving stuff under the dash on the passenger side, do I just chop it right off and run the wires or is there some less brutal way to do it?
Gary Palmer 08-02-2006 12:45 PM
Chop? What are you going to move? From what I've seen, on Honda's, their is a connector, on every wire or set of wire's and if you can find them, you just need to unplug or plug them in. When I added a/c to the 87, I cut wire's, taking it out of the junker. Putting it back in, I found every wire I cut had a connector that I could have just unplugged.
krousdb 08-02-2006 02:04 PM
Ben,
You should really take the time to splain yourself better when asking questions.
SVOboy 08-02-2006 03:00 PM
Dan,
Anyone who's had first hand experience with a wire tuck, which is what I'm asking for, will know what it is, so that's why I didn't explain, cuz it would be redundant to those I need answers for.
But anyway, a wire tuck is just hiding all the wiring in the engine bay. Currently I'm asking if I need to cut the wires to move the passenger strut mount plug and fuse box inside, because they won't fit through any holes in the firewall.
GasSavers_DaX 08-02-2006 05:26 PM
You probably need to de-pin / re-pin. Just do it one "plug" at a time and draw a diagram.
SVOboy 08-02-2006 05:30 PM
That's so much better than cutting, piece of crap that I am thinking of cutting...
