Some wire tuck advice please? - Fuelly Forums
Old 08-02-2006, 11:58 AM   #1
For moving stuff under the dash on the passenger side, do I just chop it right off and run the wires or is there some less brutal way to do it?
Old 08-02-2006, 12:45 PM   #2
Chop? What are you going to move? From what I've seen, on Honda's, their is a connector, on every wire or set of wire's and if you can find them, you just need to unplug or plug them in. When I added a/c to the 87, I cut wire's, taking it out of the junker. Putting it back in, I found every wire I cut had a connector that I could have just unplugged.
Old 08-02-2006, 02:04 PM   #3
krousdb's Avatar
Ben,
You should really take the time to splain yourself better when asking questions.
Old 08-02-2006, 03:00 PM   #4
Dan,
Anyone who's had first hand experience with a wire tuck, which is what I'm asking for, will know what it is, so that's why I didn't explain, cuz it would be redundant to those I need answers for.
But anyway, a wire tuck is just hiding all the wiring in the engine bay. Currently I'm asking if I need to cut the wires to move the passenger strut mount plug and fuse box inside, because they won't fit through any holes in the firewall.
Old 08-02-2006, 05:26 PM   #5
Moderator
GasSavers_DaX's Avatar
You probably need to de-pin / re-pin. Just do it one "plug" at a time and draw a diagram.
Old 08-02-2006, 05:30 PM   #6
That's so much better than cutting, piece of crap that I am thinking of cutting...
Suggestions from a Newbie juha Fuelly Web Support and Community News 6 10-03-2012 07:03 AM
More Fuel Saving Tip Suggestions jklaiber General Fuel Topics 1 08-11-2008 10:03 AM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
What is your favorite bulletin board software? Matt Timion General Discussion (Off-Topic) 5 03-30-2006 04:43 PM
How to check spark plug wires. CruiseControl General Fuel Topics 3 12-23-2005 10:54 PM
