-   -   Some glue that won't melt when it gets hot? (https://www.fuelly.com/forums/f10/some-glue-that-wont-melt-when-it-gets-hot-2586.html)
SVOboy 07-31-2006 08:24 AM
I had my MID mounted by gluing the hell out of some velcro strips to is and then velcro to the dash/windsheild, which worked very well.
However, while I was on vacation is got pretty hot and as a result all the hot glue melted off the mid and it fell out of it's hole.
Is there anything I got use to attach the velcro that'll be a bit more permanent?
Gary Palmer 07-31-2006 08:31 AM
SVOboy: You should try using a polyurethane based glue. An expensive example is Gorilla glue. They make a "geneic" that's available at Home Depot, that work's just as well, as far as I can tell. The glue "set's up" from a chemical reaction with the humidity. It expands a little bit when it's setting up, but once it's stuck, it is flexible, but it won't come off. I have a piece of wood I glued to a cinder block fence about 10 years ago and the board is still there, even though the gate bang's on it every time someone goes in and out of the front yard. Be wise and use rubber glove's, though, it does not wash off and it takes day's for it to wear off.
SVOboy 07-31-2006 08:33 AM
Thanks for the tip, I'll check it out!
GasSavers_DaX 07-31-2006 09:43 AM
Liquid nails that b!tch.
Gary Palmer 07-31-2006 11:17 AM
You are cruel and harsh man!
SVOboy 07-31-2006 11:21 AM
We don't like him very much.
krousdb 07-31-2006 01:24 PM
I like him.
SVOboy 07-31-2006 01:26 PM
Me too.
JanGeo 07-31-2006 02:51 PM
I would be more worried about the electronics getting cooked by the high temperatures - wrecked some Nicad cells in my GPS on the dask of the car - and the ScanGaugeI + II should be kept cooler than 160F or else they can start drawing more power when off and fry. Not good having a car fire on the plastic dash!
diamondlarry 07-31-2006 03:01 PM
You could try using the glue that they use for fixing your rearview mirror when it falls off.
