Some glue that won't melt when it gets hot? - Fuelly Forums
Old 07-31-2006, 08:24 AM   #1
I had my MID mounted by gluing the hell out of some velcro strips to is and then velcro to the dash/windsheild, which worked very well.
However, while I was on vacation is got pretty hot and as a result all the hot glue melted off the mid and it fell out of it's hole.
Is there anything I got use to attach the velcro that'll be a bit more permanent?
Old 07-31-2006, 08:31 AM   #2
SVOboy: You should try using a polyurethane based glue. An expensive example is Gorilla glue. They make a "geneic" that's available at Home Depot, that work's just as well, as far as I can tell. The glue "set's up" from a chemical reaction with the humidity. It expands a little bit when it's setting up, but once it's stuck, it is flexible, but it won't come off. I have a piece of wood I glued to a cinder block fence about 10 years ago and the board is still there, even though the gate bang's on it every time someone goes in and out of the front yard. Be wise and use rubber glove's, though, it does not wash off and it takes day's for it to wear off.
Old 07-31-2006, 08:33 AM   #3
Thanks for the tip, I'll check it out!
Old 07-31-2006, 09:43 AM   #4
Moderator
GasSavers_DaX's Avatar
Liquid nails that b!tch.
Old 07-31-2006, 11:17 AM   #5
You are cruel and harsh man!
Old 07-31-2006, 11:21 AM   #6
We don't like him very much.
Old 07-31-2006, 01:24 PM   #7
krousdb's Avatar
I like him.
Old 07-31-2006, 01:26 PM   #8
Me too.
Old 07-31-2006, 02:51 PM   #9
I would be more worried about the electronics getting cooked by the high temperatures - wrecked some Nicad cells in my GPS on the dask of the car - and the ScanGaugeI + II should be kept cooler than 160F or else they can start drawing more power when off and fry. Not good having a car fire on the plastic dash!
Old 07-31-2006, 03:01 PM   #10
FE nut
diamondlarry's Avatar
You could try using the glue that they use for fixing your rearview mirror when it falls off.
2007 Prius,
Team Slow Burn
Can I reset my city percentage? benkenobi Fuelly Web Support and Community News 6 11-12-2012 03:41 PM
Feature Suggestion: Custom Date Ranges for Timelines? terrapin Fuelly Web Support and Community News 3 06-28-2009 04:00 AM
LRR tires PDF info GasSavers_Jack General Fuel Topics 11 06-14-2006 05:21 PM
My CRX and I just wanted to say Hi! DJ Eggs And Bacon Introduce Yourself - New member Welcome 4 03-24-2006 10:47 PM
Money Back for Energy Saving Appliances! GasSavers_DaX General Discussion (Off-Topic) 0 11-09-2005 03:19 AM
