-   -   Questions about PCV (https://www.fuelly.com/forums/f10/questions-about-pcv-2263.html)
Compaq888 06-07-2006 12:51 AM
Questions about PCV
I want to change out my PCV valve and at the same time install a PCV catch can but everytime I try I run into problems.
Problem #1, Is the hose from the PCV to intake manifold rubber?? Because whenever I touch it, it's rubber but it's stiff like metal. I thought it has metal underneath it and has rubber as a sleeve. I heard people say that they make the rubber hose stuff so it can handle the pressure there. So is it rubber or is it metal and has a rubber sleeve?
Problem #2, My PCV is not the screw on type. It's the pop on type. Which is the best way to take it out??? I have the breather/separator then PCV then I have that stiff rubber line attached to the PCV by a small clamp and the rubber line connects to the Intake manifold, where it's also held on by a small clamp. So what do I do to take the PCV valve out?? Get the clamp off, rip the PCV out the breather/separator????
GasSavers_katman 06-07-2006 05:01 AM
The hose has probably gotten brittle and hard. Just go to your favorite parts store with your old one and they can cut you off a new piece of hose.
thisisntjared 06-07-2006 09:49 AM
i dont know nissans, but the hose isnt exposed to pressure, only vacuum.
mine just pulls out. and i think katman is probably right about dry rot.
Compaq888 06-07-2006 10:54 AM
I'm going to replace the hose anyway with the PCV catch can and new hose. So how do I go about removing the PCV, which part I remove first???
thisisntjared 06-07-2006 10:56 AM
who cares???? its a hose. does it matter?
95metro 06-07-2006 11:06 AM
I think he means how to remove the actual valve since it's a "pop-on" type.
Compaq, I'm not certain how to go about it, but if you don't have a Haynes or Chiltons manual for your vehicle go get one. It will explain the procedure. I've bought one for every vehicle I've worked on - they're cheap and worth a thousand times their weight in gold.
Compaq888 06-07-2006 11:18 AM
I have it but it doesn't explain anything. I have the FSM too and that doesn't explain anything either.
Compaq888 06-07-2006 11:19 AM
I know a guy who replaced his PCV at 70k and his PCV valve didn't work at all. It's bad for the engine not to have a working PCV valve. I'm at 70k too.
thisisntjared 06-07-2006 11:32 AM
i dont see how that has to do with anything i just said.
if it pops in the it should just pop out. this isnt rocket science, have you worked on you car before?
and why did you respond with 2 posts? thats weird.
Compaq888 06-07-2006 12:13 PM
Ok I will try that method. I tried like 2 times to take it out with no luck.
