Questions about PCV - Fuelly Forums
Old 06-07-2006, 12:51 AM   #1
Compaq888's Avatar
Questions about PCV
I want to change out my PCV valve and at the same time install a PCV catch can but everytime I try I run into problems.
Problem #1, Is the hose from the PCV to intake manifold rubber?? Because whenever I touch it, it's rubber but it's stiff like metal. I thought it has metal underneath it and has rubber as a sleeve. I heard people say that they make the rubber hose stuff so it can handle the pressure there. So is it rubber or is it metal and has a rubber sleeve?
Problem #2, My PCV is not the screw on type. It's the pop on type. Which is the best way to take it out??? I have the breather/separator then PCV then I have that stiff rubber line attached to the PCV by a small clamp and the rubber line connects to the Intake manifold, where it's also held on by a small clamp. So what do I do to take the PCV valve out?? Get the clamp off, rip the PCV out the breather/separator????
Old 06-07-2006, 05:01 AM   #2
The hose has probably gotten brittle and hard. Just go to your favorite parts store with your old one and they can cut you off a new piece of hose.
Kevin A Thornton
KAT Automotive
For Speed Equipment, Nitrous Express
katman@everestkc.net
For AMSOIL products
https://www.lubedealer.com/kat
For Herbs from the Amazon
https://www.168336.amazonherb.net
GasSavers_katman is offline   Reply With Quote
Old 06-07-2006, 09:49 AM   #3
|V3|2D
thisisntjared's Avatar
i dont know nissans, but the hose isnt exposed to pressure, only vacuum.
mine just pulls out. and i think katman is probably right about dry rot.
Old 06-07-2006, 10:54 AM   #4
Compaq888's Avatar
I'm going to replace the hose anyway with the PCV catch can and new hose. So how do I go about removing the PCV, which part I remove first???
Old 06-07-2006, 10:56 AM   #5
|V3|2D
who cares???? its a hose. does it matter?
Old 06-07-2006, 11:06 AM   #6
95metro's Avatar
I think he means how to remove the actual valve since it's a "pop-on" type.
Compaq, I'm not certain how to go about it, but if you don't have a Haynes or Chiltons manual for your vehicle go get one. It will explain the procedure. I've bought one for every vehicle I've worked on - they're cheap and worth a thousand times their weight in gold.
95metro is offline   Reply With Quote
Old 06-07-2006, 11:18 AM   #7
Compaq888's Avatar
I have it but it doesn't explain anything. I have the FSM too and that doesn't explain anything either.
Old 06-07-2006, 11:19 AM   #8
Compaq888's Avatar
I know a guy who replaced his PCV at 70k and his PCV valve didn't work at all. It's bad for the engine not to have a working PCV valve. I'm at 70k too.
Old 06-07-2006, 11:32 AM   #9
|V3|2D
i dont see how that has to do with anything i just said.
if it pops in the it should just pop out. this isnt rocket science, have you worked on you car before?
and why did you respond with 2 posts? thats weird.
Old 06-07-2006, 12:13 PM   #10
Compaq888's Avatar
Ok I will try that method. I tried like 2 times to take it out with no luck.
MiniStat Idea - Avg Miles / Day, Week, Month bullrider General Fuel Topics 1 10-28-2011 04:32 AM
some more familiar driving, LOL Compaq888 General Discussion (Off-Topic) 20 04-07-2009 01:37 PM
Too many entries W/ "0 MPG" DPTyphoon Fuelly Web Support and Community News 7 09-13-2008 02:19 AM
Commenting on tips MartinL Fuelly Web Support and Community News 0 08-30-2008 06:07 AM
Fuel Economy and Lease Mileage RespecttheT Fuelly Web Support and Community News 2 08-14-2008 06:42 AM
