-   -   195* Tstat (https://www.fuelly.com/forums/f9/195-tstat-1950.html)
SVOboy 04-14-2006 05:48 PM
195* Tstat
See here: https://crxmpg.com/thermostat.html
SVOboy 08-23-2006 07:21 PM
Updated pictures and did this: https://crxmpg.com/thermostat.html
MetroMPG 08-23-2006 08:01 PM
Good jorb. No leaks?
SVOboy 08-23-2006 10:11 PM
Man, I only took one hose off, what'd leak, :p
Silveredwings 08-25-2006 01:06 PM
You might have even gotten away without removing the hose: just the two bolts and pry it back. Maybe. I don't know.
SVOboy 08-25-2006 01:13 PM
Oh yeah, I definately could've, but I didn't think about it at the time. It's just a hose after all, :)
krousdb 08-25-2006 02:04 PM
How does the DIY change if you only want a 170 or 180F thermostat?
SVOboy 08-25-2006 02:06 PM
In no way, shape, or form.
eivad1 04-11-2007 12:28 AM
hows does keeping it warmer make it get better gas mileage
VetteOwner 04-11-2007 08:48 AM
2 things to help out: before you start, open the radiator cap to remove all pressure(when a car is running the cooling system has about 14psi)so you dont spray yourself or loose too much coolant(if any). do the DIY but dont tighten down the bolts too much. last thing you want is a stripped stud, or a broken stud, or a messed up hole.
