195* Tstat - Fuelly Forums
Old 04-14-2006, 05:48 PM   #1
195* Tstat
See here: http://crxmpg.com/thermostat.html
Old 08-23-2006, 07:21 PM   #2
Updated pictures and did this: http://crxmpg.com/thermostat.html
Old 08-23-2006, 08:01 PM   #3
Good jorb. No leaks?
Old 08-23-2006, 10:11 PM   #4
Man, I only took one hose off, what'd leak,
Old 08-25-2006, 01:06 PM   #5
Tuggin at the surly bonds
Silveredwings's Avatar
You might have even gotten away without removing the hose: just the two bolts and pry it back. Maybe. I don't know.
Old 08-25-2006, 01:13 PM   #6
Oh yeah, I definately could've, but I didn't think about it at the time. It's just a hose after all,
Old 08-25-2006, 02:04 PM   #7
krousdb's Avatar
How does the DIY change if you only want a 170 or 180F thermostat?
Old 08-25-2006, 02:06 PM   #8
In no way, shape, or form.
Old 04-11-2007, 12:28 AM   #9
Send a message via AIM to eivad1 Send a message via Yahoo to eivad1
hows does keeping it warmer make it get better gas mileage
eivad1 is offline   Reply With Quote
Old 04-11-2007, 08:48 AM   #10
2 things to help out: before you start, open the radiator cap to remove all pressure(when a car is running the cooling system has about 14psi)so you dont spray yourself or loose too much coolant(if any). do the DIY but dont tighten down the bolts too much. last thing you want is a stripped stud, or a broken stud, or a messed up hole.
Twitter+Fuelly TorkLugnutz Fuelly Web Support and Community News 4 01-20-2010 04:43 PM
