-   -   Graph showing 8/31 fill-up as September (https://www.fuelly.com/forums/f2/graph-showing-8-31-fill-up-as-september-16806.html)
jusuchin 08-31-2014 08:38 PM
As the title says.. just entered a fuel-up for 8/31 and it is showing up on the graph as September for averages.
BernieL77 09-01-2014 06:06 AM
Same here. I included this complaint in a Contact Us email to support. Also would rather have date & time higher up on entry screen, just under odom and gallons.
RobertV 09-01-2014 08:00 AM
This is likely due to timezones.
I'll have the Team take a look at it this week.
Thanks!
BernieL77 09-01-2014 09:36 AM
Thanks!
I pretty much doubt that because I am in US Eastern zone 5 hrs west of GMT (4 counting daylight savings) and I entered my 8/31 data some time after 7AM (probably an hour or more later).
bobbo 09-11-2014 02:10 PM
I also just noticed that some of the data points on the graph curve indicate a date one day later than my actual fill-up date.
WilliamTell 09-12-2014 09:16 AM
Fuelly doesn't sort by date
If you missed a fuel up and then found the data and put in by actual date, the odometer mileage is all screwed up and therefore the MPG is in error.
RobertV 09-12-2014 06:12 PM
If you're referring to your Aug 30th entry; the error is because you've entered it twice- https://www.fuelly.com/car/volkswagen...ell/238754/log
If you're referring to some other entry, please be specific so we can research it for you.
Thanks!
