Graph showing 8/31 fill-up as September - Fuelly Forums
Old 08-31-2014, 08:38 PM   #1
As the title says.. just entered a fuel-up for 8/31 and it is showing up on the graph as September for averages.
jusuchin is offline   Reply With Quote
Old 09-01-2014, 06:06 AM   #2
Same here. I included this complaint in a Contact Us email to support. Also would rather have date & time higher up on entry screen, just under odom and gallons.
BernieL77 is offline   Reply With Quote
Old 09-01-2014, 08:00 AM   #3
RobertV's Avatar
This is likely due to timezones.
I'll have the Team take a look at it this week.
Thanks!
Old 09-01-2014, 09:36 AM   #4
Thanks!
I pretty much doubt that because I am in US Eastern zone 5 hrs west of GMT (4 counting daylight savings) and I entered my 8/31 data some time after 7AM (probably an hour or more later).
Old 09-11-2014, 02:10 PM   #5
I also just noticed that some of the data points on the graph curve indicate a date one day later than my actual fill-up date.
bobbo is offline   Reply With Quote
Old 09-12-2014, 09:16 AM   #6
Fuelly doesn't sort by date
If you missed a fuel up and then found the data and put in by actual date, the odometer mileage is all screwed up and therefore the MPG is in error.
WilliamTell is offline   Reply With Quote
Old 09-12-2014, 06:12 PM   #7
RobertV's Avatar
If you're referring to your Aug 30th entry; the error is because you've entered it twice- http://www.fuelly.com/car/volkswagen...ell/238754/log
If you're referring to some other entry, please be specific so we can research it for you.
Thanks!
