VX at the track
I took the VX to the drag strip today. I got to make 6 passes.
Termperature: approximately 60 degrees Best 1/4 mile time: 17.577 Best trap speed: 75.50 mph Best reaction time: 0.001 sec All times were within 0.2 seconds and 1 mph except for the 4th pass, where I missed the 1-2 shift. These times will serve as my baseline for any performance mods I may make in the future. |
Interesting numbers..
ORP???
*Edit* Damn thing keeps changing that from all capitals to "proper". Adding extra "?" fixed this... |
I also had a relatively nice burnout. I'll try to get one on film at the end of the summer. |
My 6 passes:
R/T 60 ft ? mi Trap Speed .339 2.612 17.684 75.16 .043 2.669 17.762 75.50 .001 2.622 17.719 74.51 .187 2.549 17.577 74.71 .102 2.637 17.672 74.66 .170 2.714 17.751 74.76 It is notable that a stock VX would run the 1/4 mile in 17.3-17.4 @ 76-77 mph. It looks like my VX has not lost all that much in 15+ years and 230,000 miles. (How many owners can claim that their car rolled over to 230,000 miles while going down the racetrack?) |
At what RPM are you shifting?
Obviously you are finishing in 3rd... |
On my quickest runs, I was shifting at 6000 RPM in both 1st and 2nd. I tried shifting at 5800 twice, and those were my 17.7 runs.
The first 2 runs had the vertical intake tube on the car. I took it off for the last 4. It did not make a difference. Over the summer, I plan on removing the A/C and installing a short ram intake, or perhaps a cold air intake. I'm hoping to get down to a 17.1 or 17.2. Of course, I will add more weight if I install the anti-roll bars I want. I will also probably install a strut tower brace up front (any suggestions?). I am wanting to autocross the car in September. |
That IS good! I love when cars keep their strength.
By anti roll bars, do you mean a partial roll cage? Strut tower bars make a difference, and depending how deep the AutoX bug gets into you, there are alot of suspension options. I get all of my parts either used, or at a discount from forums. You could look for people upgrading. You must be a good driver. Great reaction time. You must not have spent much time spinning. |
I recently installed Eibach Pro springs and shocks. I need to replace the bushings next. I would like anti-roll bars (also called stabilizer bars or anti-sway bars) on the front and rear, as the VX does not have them from the factory. This is what I want:
https://www.autoanything.com/suspensi...A2548A0A0.aspx |
