Windows XP
All night the Defragment program was stopped:
[c:] Paused for Volume Shadow Copy I restarted the program and the same thing popped-up. Never saw this before. What is it? |
I can't say that I've seen that message before. You could stop the Volume Shadow Copy service while it's running and that ought to take care of it. However, I recommend using Defraggler instead of the built-in defragmenter.
https://www.piriform.com/defraggler It's small, fast, effective, and robust. |
Before the Defrag, I ran CCleaner and deleted;
Internet Explorer: temporary internet files cookies history recently typed URL's Index.dat files last download location Windows Explorer: recent documents search autocomplete other explorer MRU's System: empty recycle bin temporary files clipboard memory dumps Chkdsk file fragments window log files So, the question is, if some of the above was a no-no? |
The error you got was not related to anything you did with CCleaner.
Volume Shadow Copy is a background filesystem subsystem that helps Windows do backups of files that are in use and allows Windows Vista and later to keep backups of files when you change them. |
If they are necessary, how do I get it back?
You mean if you need to retrieve an older version of a file that you changed? In XP, there's nothing you can do. XP doesn't keep backup versions. It only uses the volume shadow copy service if you're using a backup program.
In Vista, you can use this: https://www.shadowexplorer.com |
I could go back a week on Carbonite.
Turn off the restore points in your system properties then restart, that should take care of it.
