Windows XP - Fuelly Forums
Old 01-01-2010, 11:01 AM   #1
Windows XP
All night the Defragment program was stopped:
[c:] Paused for Volume Shadow Copy
I restarted the program and the same thing popped-up.
Never saw this before. What is it?
Old 01-01-2010, 11:36 AM   #2
I can't say that I've seen that message before. You could stop the Volume Shadow Copy service while it's running and that ought to take care of it. However, I recommend using Defraggler instead of the built-in defragmenter.
http://www.piriform.com/defraggler
It's small, fast, effective, and robust.
Old 01-01-2010, 01:14 PM   #3
Before the Defrag, I ran CCleaner and deleted;
Internet Explorer:
temporary internet files
cookies
history
recently typed URL's
Index.dat files
last download location
Windows Explorer:
recent documents
search autocomplete
other explorer MRU's
System:
empty recycle bin
temporary files
clipboard
memory dumps
Chkdsk file fragments
window log files
So, the question is, if some of the above was a no-no?
Old 01-01-2010, 02:26 PM   #4
The error you got was not related to anything you did with CCleaner.
Volume Shadow Copy is a background filesystem subsystem that helps Windows do backups of files that are in use and allows Windows Vista and later to keep backups of files when you change them.
Old 01-02-2010, 01:10 PM   #5
If they are necessary, how do I get it back?
Old 01-02-2010, 01:52 PM   #6
You mean if you need to retrieve an older version of a file that you changed? In XP, there's nothing you can do. XP doesn't keep backup versions. It only uses the volume shadow copy service if you're using a backup program.
In Vista, you can use this:
http://www.shadowexplorer.com
Old 01-02-2010, 04:07 PM   #7
I could go back a week on Carbonite.
Old 01-04-2010, 09:25 AM   #8
Turn off the restore points in your system properties then restart, that should take care of it.
- Kyle
turbocharging 2000 civic lx for FE? hi tech hillbilly Experiments, Modifications and DIY 18 12-30-2012 06:31 AM
MPG: gasoline, diesel, CNG, etc equivalency jhu General Fuel Topics 6 07-05-2009 03:08 PM
ScanGuage Diplay(s)/Function(s) GasSavers_goldie General Fuel Topics 10 04-06-2009 03:45 PM
Buck From KC BuckFiftyCutty Introduce Yourself - New member Welcome 0 04-18-2008 05:43 PM
College Aero trebuchet03 Aerodynamics 5 05-13-2007 08:04 PM
