Changing wheels/tires any guess on the mpg gains?
I am currently running stock del Sol Si wheels with 195/60/14 tires.
Average weight of a 195/60/14 tire is 18.3lb (calculated from tire rack tire weights). The del Sol wheel weighs 15lb. Total unsprung rotating weight per wheel is 33.3lb. I am hoping to snag a set of Civic VX wheels with 175/70/13 tires. Average weight of a 175/70/13 tire is 14.8lb and the VX wheel weighs in at 9.7lb. Total unsprung rotating weight per wheel would be 24.5lb (reduction of 26.4% or 8.8lb per wheel, 35.2 total) The vehicle velocity would also change by reducing tire circumference by about 2.5% (my speedometer is currently 2.1% too slow because my tires are larger than stock and the vx tires would make it 0.4% too fast) The frontal area would be reduced because the car would sit 0.3 inches lower and each tire is 0.8 inches narrower. seems pretty dramatic to me when you combine the reduced area, reduced resistance to rotation and reduced total mass. the only drawback is the smaller circumference which would make the engine run at higher rpms (81 more rpms to maintain 70mph). any educated guesses as to the mpg gains to be found? thanks, -tony |
Those tires will need more pressure than the existing tires. Also, don't forget that the odometer will suffer from the same change in accuracy that the speedometer does, so calculate that in to your FE calculations.
I am skeptical about the rotating weight issue. Based on the science that I know about it and the words of experts in other contexts, I believe that it's a myth. |
However reciprocating mass (pistons, valves, etc.) do "suck" energy to move. -BC |
Going to a smaller wheel and tire is going to hurt you because of the difference it will make in gearing. The engine will be turning more RPM's to do the same amount of work.
So if you did an A-B-A with a scangauge and started the measurements when you were allready at cruising speed then you would see no improvement. BUT, if you consider the full mileage covered by a full tank (like I do) then you should see more of a difference. That is why racers use lighter wheels, because less energy goes to accelerating the rotating mass and more energy goes into accelerating the vehicle. If less energy is needed to drive the same way that I allready do, then less throttle would be applied and less fuel burned. Quote:
I contend that if every other parameter was maintained equal, and a vehicles rotating parts were replaced with lighter weight materials (from the crank pulley, through the drivetrain, all the way to the tires) that the vehicle would be more efficient. I am assuming of course that techniques like P&G are not used because that in fact requires rotational inertia to extract energy back out of on the glide. My assumption is for the standard American driver or for people like myself who accelerate normally through the gears and use cruise control often. And Ford Man, I mentioned in my orginal post that to maintain the same vehicle speed (69.03mph, my car would change from 3200rpm now to 3281rpm with smaller tires) but I don't think 81rpm will consume significantly more fuel. i am considering a transmission change in the future however that would bring the rpms below stock at cruising speed. Sorry for the long post, and I am very open to criticism or correction because that seems to be the best way to learn. -Tony |
I say go ahead, and we'll see what the long-term effects are...though there are too many variables to say for sure which are responsible for any measured effects. It's my prediction that there won't be much difference. There's one way to learn that's better than being corrected: Finding real world data. |
I have found on my Hondas over the years that reducing wheel weight improves ride quality, nothing more.
However, switching to smaller wheels means switching to thinner tires, which does in fact improve mileage significantly. It's nearly impossible for me to predict how it would affect your fuel economy with so many real world variables to contend with, but I wouldn't expect more than a couple miles per gallon. |
After having had four sets of tires of varying size on the CRX, I would say that any improvement would be so small as to be lost in the background noise. How long you idle at the Burger King drive-thru twice a week, or a small change in PSI would make as much of a change.
IMO. |
We shall see
Well, the concensus on this forum seems to be that there will be negligible gains from the change.
But, I need tires anyway so I will be picking up and installing the VX wheels today after work. I start back to school next week (125 mile a day commute) so I will be updating my gaslog soon and often (fillup about once a week). I will post back here when I have results. |
