cheapybob -
I set the scangauge to the engine size and look for relative changes in my MPG runs. Since that is my operating condition for all my runs, I think the my claims of *relative* MPG gains/losses are valid. I have chosen to look at the "90 day outlook" instead of the tank by tank, because that should reduce the overall error over time. For example, in the last 90 days I have driven 4570 miles for a 38.87 MPG average. Since the sample size is large I think the adjusted odometer based MPG is accurate. When I see a "relative gain" with a mod over time, the mod stays. I just can't afford the time to use the same pump. I am a commuter with a messy 1.5 hour one way commute. At best, I try to keep to the same station, but use whatever pump is available :( . There's one fellow who records the station and the pump # in his gaslog. Maybe I'll do the same. CarloSW2 |
I'd guess that pumps that were on the level at the same station would be the same model and therefore give pretty good results. I think the key is to have it on level and finish the fillup slowly, hopefully the same way each time. If you get it within 8 oz of the same point each time and are filling at 1/4 tank left, your mpg accuracy will be high. Relative gain is "nice", but real, believable results for each tank are "priceless". You can always calculate a 90 day average if you have accurate fill and distance data.
I think the IGN number it shoews is probably spark advance in degrees, so the higher it is, the better, and when you see it dropping abnormally, I'm guessing it has sensed ping and is retarding spark to compensate. Anyway, that's a long commute, so any improvements will payback quickly. If I were you, I'd definitely switch that trans at first opportunity. |
cheapybob -
Re: MAD!! gear swap https://www.saturnfans.com/forums/sho...3&postcount=45 Quote:
That saturn 5th swap can be done in the car. The most expensive part is the gasket (kit), but it's just a cover so you can improvise. I wound up using kite string and rtv on the shifter cover of mine and it is has worked well so far.
Cheapie, you gotta try a kill switch and some P&G sometime. You'll be all like "Dang, why didn't I do that sooner"? |
Also, the SG2 uses the injector pulses as reported by the computer to accumulate fuel usage, I think. Otherwise the fuel used when filling the tank wouldn't match what the scangage thought was used. |
What is "P&G"? |
I tried using the IAT mod again at 260F. I think it's tricking the SG2 more than anything. The Gauge reported a 30mpg tank while the actual tank was 23mpg. I did use a lot of burn & glide and shutting off the engine at long stop lights.
popimp -
CarloSW2 |
cheapybob -
cfq83:
Did it work for you? |
