OkeeeDokee...
When do modifications to one vehicle make it, for all intents and purposes, another vehicle? As far as the pre or post '08 numbers go: I'd think that using the EPA number valid at the time of manufacture could be the value entered by a member. That number could then be used to "convert" to an 08 equivalent using a fixed factor. If an '07 "loses" 15% compared to the same, but '08 model, then the factor would be a loss of 15%. A 2000 with an EPA combined of 36 mpg would be entered by the member as 36 mpg, but the value used for comparison would be 30.6 mpg or 15% less. Yeah, that means a software rewrite to fudge all 2007 and older by 15% but leaving everything after that model year un-fudged. I don't envy you the task. |
We decided a while back to stick with the car you bought it as/it was built as. If you go through the trouble to do a tranny swap or such to get better mileage, that should be noted.
Lug_Nut -
If I were you I would have wanted to choose the EPA numbers that match the new drivetrain, because in my mind, the drivetrain is the dominant factor. However, those numbers may not be available in cases where the new drivetrain doesn't have an EPA equivalent. In that case, I would have done exactly what you have done, i.e. use what is available. The key is that you have *documented* the origin of your EPA figures and what you have done to the car. Fine by me. I think that over time there are going to be some cars that are "far out there" in terms of what the EPA can support. What will DaX do about his Honda Beat, and what will ToeCutter do when his electric is finished? In terms of programming, Matt is already going to issue a "Reset" for all our EPA numbers. I don't have a problem with this, especially if the new EPA mechanism is able to "pull" the numbers from the website. In it's present form it is actually more error prone than what I *think* Matt is proposing. Imagine if we were an even bigger website of say 10,000 or more members. Now that would be a mess!!!!! CarloSW2 |
I just changed my figures (you can see it in my signature). |
