yup those plugs look perfectly normal
So is it safe to say that this mod with the resistors is busted? What's the ideal Intake Air Temp?
Has anyone tried this with the water temp sensor?
https://www.hydrogen-boost.com/newsletter.html "Will operating my vehicle at a leaner mixture with Hydrogen-Boost, cause damage to my valves? With Hydrogen-Boost seeking to run on the leanest air/fuel mixture that has acceptable torque and power, in pursuit of the best possible gas mileage, we have had repeated questions from misinformed customers concerning whether they would burn their valves by running the extra lean mixture. I am sure the misinformation comes from the aviation field. Being an aviator until last year's near fatal experimental aircraft accident, I know that piston engine aircraft take off and climb at maximum power, and cruise at a leaner mixture, watching the EGT gauge to insure a safe temperature. Of course we all assume that safe temperature means a temperature that doesn't burn the valves. This information gets us to assume that an electronic fuel injected engine runs at the rich mixture that is cool enough to protect the valves from burning. Most also assume that if we lean out the mixture we will be in danger of burning the valves. A too hot exhaust gas temperature also would indicate a too hot combustion temperature that happens to produce NOx, the oxides of nitrogen that are considered as toxic pollution. What most of us don't know is that during warm up and acceleration the EFI (electronic fuel injection) engine does indeed run with a rich mixture, but during cruise the engine control unit (ECU) runs in what is called closed loop operation, which targets a 14.7 to 1 air fuel ratio. This ratio is called stoichiometric, meaning that there is a perfect mixture of air and fuel to insure complete combustion. This also happens to be the perfect mixture to get the highest temperature of combustion, and therefore the highest exhaust gas temperature (EGT). Any leaner (more air) mixture will cause a cooler combustion, and any richer (more fuel) mixture will also cause a cooler combustion. The following quote was obtained from https://www.sdsefi.com/techegt.htm and is chemically accurate: Some gauge manufacturers say you should tune to achieve maximum or peak EGT for maximum performance. This is incorrect. Peak EGT generally occurs at an AFR of around 14.7- 15.0 to 1 on gasoline. This is far too lean for maximum power and is dangerous under continuous WOT conditions. Many people think that the leaner you go, the higher the EGT gets. This is also incorrect. Peak EGT occurs at stoichiometry- about 15 to 1 for our purposes. If you go richer than 15 to 1, EGT will drop and if you go leaner than 15 to 1 EGT will ALSO drop. It is VERY important to know which side of peak EGT you are on before making adjustments. It is safe to say that peak power will occur at an EGT somewhat colder than peak EGT. As you can probably figure out by now, leaning the mixture from the target 14.7 to 1 will NOT cause a hotter exhaust nor will it cause you to burn your valves. This is not to say that leaning the ECU's program under all conditions will cause a cooler exhaust. There is one condition that could be hotter and that would be running at WOT (wide open throttle) at 14.7 to 1 instead of the programmed 13 to 1. A continuous running at this condition might indeed burn your valves. But how often would a mileage conscientious driver equipped with Hydrogen-Boost want to run at WOT for extended periods of time at 14.7 to 1 mixture? First of all a conscientious driver would be following the driving tips in the manual which discourages WOT driving all together, say nothing about an extended WOT operation. Also if a Hydrogen-Boost system is adjusted properly, it will be running at a much higher (leaner) mixture than 14.7 to 1, even at full throttle. Being a research scientist, I don't like to take anyone's word for anything so I have ordered two EGT gauges, both of which can read the temperatures of two sensors. I will verify all that has been written in this newsletter and will report the results in a later issue. So to answer the original question: Will operating my vehicle at a leaner mixture with Hydrogen-Boost, cause damage to my valves? NO." "Am afraid that the MYTH of valve burning and the reasons may have had its roots back when cars were tuned by hand and people did lots of things wrong when they adjusted the settings. The popularity of the myth might have its origin after seeing an acetylene torch cut thru steel. Not stainless tho. A torch won't normally cut stainless. BTW I learned welding in the Air Force. My times on dynos shows that a lean mixture leads to misfires that may occur every other cycle and give a tell tale bang out the exhaust. It is well known that a lean mixture COOLS the combustion temperatures. The peak temperature happens when the cylinder is running at or slightly richer than a stoichiometric mixture. Too rich or too lean drops the peak temps. But the slow burns from lean mixtures may exit past the exhaust valve still burning and ignite unburned fuel in the pipe or muffler or cat-con. Modern cars have computers that adjust mixture and engine parmeters without human help. The sensors feed their data to the computer and the computer does what it is programmed to do. Unless someone tampers with a car computer, the engine will behave properly. My previous Email has a quote from Jack Henry who strongly emphasized the relationship between good mileage and engine performance. For example, too lean of a mixture would NOT give good mileage. How could it? Fuel can go unburned out the exhaust with lean mixtures. When your ScanGauge says you are getting good mileage, your engine will last the longest possible. SO it is NOT possible to damage valves or anything else at peak mileage. Back in San Pedro, we ran engines for days at a time under load at peak economy without problems in both gas and diesel engines. Louis LaPointe" If you go too lean you get misfires? I THINK people using Halo plugs can get better ignition with a lean mix. Can anyone verify this? |
lean burn efficiency. . .
or maybe lean burn is just a way to reduce the minimum power output while keeping the engine running. It doesn't mean the engine is producing at its most efficient. I wonder if a hybrid's motor would use lean burn for anything other than to cool combustion for emissions.
I put the left over resistors that I had ,in series, and came out with some numbers just in case any other Dodge/Chrysler owners wants to try this mod.
450 Ohms - 235F 550 Ohms - 225F 660 Ohms - 215F 990 Ohms - 191F 1130 Ohms - 182F 1350 Ohms - 173F 1570 Ohms - 164F 1900 Ohms - 155F 2000 Ohms - 152F 2220 Ohms - 146F Can someone explain to me what the Air Temp has to do with burning lean/rich? Also are there any success/failure tests? |
Diamondlarry so what temp/resistor should I try? I tried the 330ohm and the was reading 260F. The SG2 was reporting mpg that was way too high.
On my Saturn I used two 220 ohm resistors in parallel which is 110 ohms. This gave me a reading of 247F which was the highest temp reading I could get before the ECU freaked out and threw a code. So, I would say to keep going as high on the temp reading as you can before you get a CEL.
I think it's been mentioned before but, I think this mod may be fooling the Scanguage into higher mpg readings. You'll want to do before and after testing to verify this. |
