I checked my thermostat and it appears to have a 195 degree thermostat btw.
I'm using a fuel heater on my Geo Metro. An image can be seen here
www.livesteaming.com/metro.htm I have to admit I was nervous about using but after running it disconnected from the fuel supply for a week I hooked it up. The copper fuel line got too hot to touch without fuel. With fuel it is just warm. I cannot tell you if this mod has made a difference because I do not have the time to test every mod individually. I'm happy though with the current approx. 62 mpg. TH |
I don't mean to criticize, but I am curious why we would want to heat the fuel when the manifold is heated, and with the warm air intake the fuel would quickly become whatever the intake air temp is.
Fuel injection has a cooling effect as the fuel evaporates into the air causing a drop in temperature. If you can add the heat needed to make the fuel vaporize you wont have to take it from the air after injection. Toyota relies on this for their Tundra and 4Runner TRD supercharger kits.
Why heating the fuel gives a benefit? The point of a WAI is to make the air less dense so you are basically decreasing displacement by decreasing the amount of air the engine can take in. This means you have to give the engine more throttle to get a given amount of power and you get reduced pumping losses as a result. The heated fuel keeps the air from cooling down just before it enters the cylinder. |
Just because it cools to less than ambient doesn't mean it's over 100% efficient. To be over 100% efficient the intercooler would have to cool the air going through it to a temperature lower than the coolant going into the cooler.
What you are talking about is just 70% efficiency with a lower starting point than ambient which is why it can cool to lower than ambient. |
In my opinion this is nuts. All of you know that when you heat the gas you are running on mostly vapors which are much more volatile than liquid. I wouldn't feel safe in a car that the fuel was 400 degrees.
Am I wrong or right in this thinking? |
