VetteOwner |
10-29-2008 07:08 PM |
Originally Posted by Danronian
(Post 122616)
I had idle problems with my first VX motor (had 238k on it) and I found it was a sticking throttle body that needed to be lubed and cleaned. I also found the throttle cable was adjusted wrong. To me it sounds like it is either a vacuum leak or the throttle body/throttle cable sticking.
yea age and carbon build up will do those things to any car, clean it out (run some seafoam thru the gastank) or open the throttle and scrub with soem seafoam on a toothbrush or somehting.
