My VX idle bounces when rolling in neutral - Fuelly Forums
Old 07-17-2008, 04:47 AM   #1
djenyc's Avatar
I'm puzzled by bouncy idle on my 1994 VX - It idles fine most of the time, except when rolling in neutral (e.g. coming to a stop light) the idle bounces up and down between 800 and 1200RPM; as soon as the car stops completely, the idle stays steady at around 900RPM.
A bit of history on that VX:
When I got the car this past winter it had bouncing idle at all times after the car would warm up - I replaced O2 sensor, spark plugs, cleaned EGR, cleaned IACV and cleaned throttle body and checked resistance of TPS with no effect on the idle.
A few months ago I got a junk VX engine and swapped IACV - that fixed the idle when the car was not moving, but still had a problem when the car was rolling in neutral.
A month ago I picked up 92 VX that is Canadian model; it idles fine. I swapped IACV between 92 and 94 VX. After the swap - 92 VX continued to idle fine; 94 VX started to have bouncy idle when at stop AND when rolling in neutral.
Now I swapped IACVs back and 92 VX continues to idle fine; and 94 VX now idles fine at stop, but bounces when rolling in neutral, so that condition is repeatable ...
I made sure to drain air out of coolant lines when doing IACV swaps and checked coolant level. What can this be?
Thanks
Ross
djenyc is offline   Reply With Quote
Autotrans coasting to stop VNelson Hypermiling 13 12-25-2007 09:05 PM
Timing chain and FE bowtieguy Experiments, Modifications and DIY 22 11-11-2007 08:48 AM
195* Tstat SVOboy Experiments, Modifications and DIY 12 04-17-2007 07:27 AM
Scangauge gets website upgrade ketel0ne General Fuel Topics 1 08-10-2006 05:52 PM
