Ryland.....
Your 1st paragraph IS exactly what caused me to wonder how this would work at all. Apparently it will work on newer vehicles? |
brelandt, Your comment about deisel engines being regulated by fuel delivery and not a throttle plate... that is one of the reasons they get better mpg than gas engines at partial throttle. No pumping losses across a throttle pate. the problem of pumping loss as I understand it: A partially open throttle reduces the manifold pressure, which reduces the pressure on top of the piston as it is travelling downward, sucking in air/fuel. Since the pressure on top of the piston is much less than the crankcase pressure, the pressure force is working against the piston (slowing the engine). At 90% throttle opening the manifold pressure is higher and it isn't as bad. Quote:
