From what I have read , auto manufacturers deactivate the cylinder after the firing stroke and use the exhaust gas in the chamber as an easily compressable spring. This works fine , for a while. In time the exhaust gas leaks out (valves and ring leakage) and it starts to compress air , then the advantage is gone., and now you start loading up the other cylinders. My answer was in reference to Bruce's question ?What if you were to merely block off the ports on the intake manifold by sandwiching a steel plate between the intake manifold and head rather than disabling the valves?? As Bruce would be vac'ing + compressing air immediately it wouldn't work. My suggestion to remove the plug to allow air to vent in and out easily would provide an improvement by not trying to compress the air. But as far as existing cylinder deactivation is concerned , with only a 5 to 10 % increase in FE it is hardly enough gain to warrant such a complicated system. |
Air movement does incur a pumping loss, but the biggest contributor, what people talk about wrt gassers, is the pressure difference between the crank case and the closed cylinder as it moves down. At low load there is less air in each cylinder, which means the delta pressure between the crank case and cylinder at the bottom of it's stroke is significant, with the crank slowing significantly before the air/fuel is ignited because of this.
Gammy is right, although I don't think the exhaust and intake valves need to be blocked off. Just remove the plugs from the cylinders you don't want to run and make sure there is no fuel getting to them. Actually, leaving the exhaust/intake valves functional would be an advantage, since this lets in more air initially, so as the piston moves down there's already more air in, so less has to come through the spark plug hole which may reduces any losses from the smaller (but not static) pressure difference between cylinder/crank case while the piston is expanding, not to mention that more air will get in because the other two pistons need more air/fuel to do the same amount of work as four did during the same time span. All in all, I think you could easily see a 20% increase in FE if this worked. Do eeet! :D Something else I just though of, get a normal gasoline PFI engine from the junkyard, and set it up for TBI/SAFI (megasquirt or whatever). This way, you can put a solenoid on each of the fuel injection holes that will open whenever you want. At a cruise you can fire one cylinder per rotation sequentially while opening the other cylinder's solenoids/cutting fuel to them. I'm not sure if this would result in some funky vibrations, but since you can fire a different cylinder/combo of cylinders each engine cycle, maybe you could work something out for best fuel efficiency/least vibrations. Anyway, as for your first experiment, cutting fuel to two cylinders, you should see some increase in mileage. Removing the injectors from those holes should net a larger increase in efficiency. If you had a nice long stretch of road next to a gas station where you could go at some low speed in top gear this would be a great experiment, checking the increase in efficiency after fuel deactivation and then after pulling the spark plugs. |
Going to the variable displacement idea, if the engine only needs 20hp at 65mph, by only using say, four out of eight, the throttle can be opened wider since those active cylinders need twice as much air to burn twice as much fuel (or remain closed and act as springs if vibrations are a problem), and since the other four aren't burning any fuel, they'll suck in twice as much air too, w/o any probs, and the difference in pressure between the cylinder/crankcase will be much smaller with more air in all the cylinders. I think the biggest hurdle was making the transition and operation with fewer cylinders smooth/reliable. One more example is the Atkinson cycle. Toyota keeps the intake valves open longer so that a larger portion of air can be pulled in, then closes them once the cylinder has moved up and pushed enough air out for the air/fuel ratio to be correct. By letting more air in the pressure difference between the cylinder/crank case is smaller, so less negative work is done. Quote:
https://www.fueleconomy.gov/feg/tech_engine_more.shtml Potential Efficiency Improvement: 7.5% https://ezinearticles.com/?Cylinder-D...ing?&id=226193 Although typical gains range in the neighborhood of just 5-7%, https://www.worldcarfans.com/news.cfm...r-deactivation Preliminary testing of the 2007 Chevy Impala equipped with the 3.9L V-6 with AFM indicates an estimated 20 mpg in the city and 29 mpg on the highway ? improvements of approximately 5.5 percent and 7.5 percent, respectively. https://www.edmunds.com/advice/specia...1/article.html On the regular EPA mileage test, DoD delivers fuel economy improvements of 6-8 percent https://en.wikipedia.org/wiki/Active_Fuel_Management EPA tests show a 6% to 8% improvement in fuel economy https://www.auto-report.net/j30avcm.html While such cylinder deactivation strategies are expected to improve fuel consumption by around 5% https://autospeed.drive.com.au/cms/A_2618/article.html By keeping the intake and exhaust valves closed, it creates an ?air spring? in the combustion chamber ? the trapped exhaust gasses (kept from the previous charge burn) are compressed during the piston?s upstroke and push down on the piston during its downstroke. The compression and decompression of the trapped exhaust gasses have an equalising effect ? overall, there is virtually no extra load on the engine. https://en.wikipedia.org/wiki/Active_Fuel_Management In order to deactivate a cylinder, the exhaust valve is prevented from opening after the power stroke and the exhaust gas charge is retained in the cylinder and compressed during the exhaust stroke. Following the exhaust stroke, the intake valve is prevented from opening. The exhaust gas in the cylinder is expanded and compressed over and over again and acts like a gas spring. https://www.carterdodgechrysler.com/n...dge-magnum.htm Deactivation occurs during the compression stroke of each cylinder, after air and fuel enter the cylinder. Ignition then occurs, but the combustion products remain trapped in the cylinder under high pressure, because the valves no longer open. No air enters or leaves. During subsequent piston strokes, this high-pressure gas is repeatedly compressed and expanded like an air spring, |
I think theclencher's take on mileage increase is accurate. The EPA tests have the car bouncing around in terms of speed, so who knows how often DoD is actually activated. I'm guessing that a four cylinder with ghetto DoD could see as much as a 20% increase cruising at 45-55mph because it'll always be on unlike commercialized systems by GM, etc... that are designed for the overall driving experience.
From one of the articles Gammy posted Quote:
It dragged it up to 22mpg , which is still S&/T FE. I never saw any 20% improvments when talking about small 8's 6's ,,and 4s. For a budget deactivated gheto car why not take out the piston and rod , block the ports and add ballance weights to the crank pins. Then you have real cylinder deactivation with far higher gains. |
Because it's easier to just kill two injectors, have two cylinders firing that require twice as much air from the throttle, with the two dead cylinders getting twice as much air as well... Compared to pulling apart the engine to have what would a bit more efficient (no friction from movement and no pumping losses from pulling the air in/pushing it out, even though these pumping losses are small compared to the usual pressure difference imo). I think killing two injectors and removing those spark plugs will see a far bigger increase over stock compared to the increase from putting weights on the crank pins/blocking it off over killing two injectors and pulling the plugs.
Granted, how much pumping losses are reduced depends on gearing, cylinder size, etc... But if large SUV can see a 20% increase at a steady cruise, I don't see why two cylinder operation for a large four cylinder car wouldn't result in similar economy gains at a steady speed. And, unlike the usual DoD systems, this one can be activated/deactivated at will by putting switches on select injectors. I think more than a 20% increase is possible because the FE minded driver can always have the system on. We need someone with a scanguage or supermid to figger this'un out! :D |
Your dreaming. ! Removing the mechanical parts and rebalancing is the ulitimate solution if you wish to take that route. You have no frictional or pumping losses whats so ever. How can simply removing the plug off an injector equal that . SHEESH. |
ogl: you are not alone in the issue, but you have covered all points i would try to make haha.
This engine for example, is probably around the 500g/kwh area at 55mph in top gear. https://www.v6performance.net/gallery...0805_Fig11.gif By running off of half the cylinders, we double the torque made by the other half, and double the air flow to all, probably going from the 500g/kwh to the 300g/kwh area. Now, we can also pull out the cylinders that aren't firing to cut the remaining friction and pumping losses in half, but if the minimal BSFC is ~240g/kwh (actually less since we'd only have two cylinders), how much more of an increase in efficiency are we gonna see going from ~300g/kwh? |
