11-16-2005, 10:30 AM
Cylinder Deactivation
Author: Harrell, Rick
Publication:www.gassavers.org
Date:11/16/2005
Background:
Some of today's modern V-8 and V-6 engines utilize a complex mechanism known as "cylinder deactivation" or "displacement on demand". This feature is reserved for the newest models and those vehicles with the need for a large engine (such as an SUV, Pickup Truck, or Minivan). In some cases, as the DaimlerChrysler Charger/Magnum, a large "HEMI" engine uses cylinder deactivation to cut half of the cylinders under steady cruise with light throttle (on a car/wagon with a powerful engine). GM and Honda also have similar technologies. The process is quite complex and requires cutting fuel and air to the cylinder bank using a mechanical process.
This author has brainstormed with this idea before it has become mainstream, but I never really realized how to do it. I then learned on this website that merely cutting power to a series of injectors would essentially achieve similar action. This seemed much easier to implement. The test vehicle is an American-spec 1998 Acura Integra LS 3-door, with the 1.8-Litre DOHC, Non-VTEC, 16-valve, 4-cylinder engine, with an automatic transmission. Although the experiment did not achieve increased fuel economy, further investigation could yield a way to cut fuel to all cylinders during zero throttle input (coasting) and could potentially increase economy. During coasting, this model of vehicle pulses fuel into the cylinders. Complete shutdown could, hypothetically yield an increase.
I would not recommend using this procedure on the 4-cylinder engine configuration, similar to mine (described later). Inline-5, Inline-6, V-6, V-8, and potentially H-4 and H-6 (Subaru, Porsche) engines could yield a balanced firing order and even cylinder placement. Unfortunately, my engine failed to perform due to reasons which will be described later.
Hypothesis:
Deactivating cylinders in low engine-load situations and/or zero-throttle input will yield higher fuel economy.
Results:
At idle, deactivating the 2-cylinders that worked together yielded in a very unbalanced combustion process, and caused the engine to rock violently forwards and backwards. The only way I could get smooth operation was to run the vehicle at engine speeds upwards of 4000 RPMs. The "LS" engine is a transversely-mounted 4-cylinder that fires at 1-3-2-4 – meaning that cylinder #1 combusts, moves downward, then the same for #3 (probably together). Then the cylinder moves back upward into the compression cycle while 2 and 4 fire. Cylinders 2 and 4 are at Top-Dead Center, when 1 and 3 are at their bottom-most position, etc. Basically there would be a firing of the top 2 cylinders (#2 and #4), then a long pause when 1 and 3 came back up and then down, creating very unbalanced sequence of events and a rocking sensation. This wasn't noticed at higher RPMs because the cylinders were coming back around quick-enough to not create a significant vibration. By the way, cutting fuel only and not fuel and air, results in the deactivated cylinders becoming air pumps. This may have confused the oxygen sensor and catalytic converter. A computerized fuel management system would be recommended to work in-tandem with the deactivation
Operating at 4000+ RPMs and utilizing 2 cylinders resulted in the 2 cylinders becoming overly rich, and used more fuel that if all 4 were working as usual. For those out there who have an engine that would accommodate this idea, feel free to experiment, but first
Disclaimer:
You are assuming your own risk by performing modifications to a vehicle that is either stock from the factory, or has been modified within the scope of local laws; furthermore, this author and/or this website cannot be held responsible for damage resulting from experimentation.
Implementation: - Do I really want to do this? and if I mess this up badly, do I have another vehicle to get me to where I want to go while this one gets fixed. Be cautious, this is not your everyday experiment.
- Get to know your engine. Using the Internet or repair manuals (available at your local library's reference section), find out what engine you have and the following:
- Cylinder Placement
- Firing Order
- Cylinder Numbering Convention (which is which)
- First, figure out where your pistons are. The repair manual/Internet should be able to tell you; for example, where your pistons are located in relationship to one-another. Usually cylinders like to stick together in 2's, 3's, and maybe even 4's. {diagram of a V-8}
- It's a balancing act. Try to determine the best deactivation of cylinders by when they fire and their position. The rule-of-thumb is to avoid an uneven firing or placement of piston position.
- One you have a basic idea of which cylinders to deactivate, and if you have an engine that has easily accessible fuel injectors that can be easily disconnected, then disconnect them and start the vehicle. (This author's vehicle has a squeeze connector that allowed easy disconnection of the injector [pic]). I do not recommend disconnecting them when the engine is running for safety considerations and the potential of arcing/shorting the injector connection. This author accidentally shorted out the fuel-injection system and was unable to start the vehicle. Having thought I burned-up the car's ECU, I thought I fried the car's computer. Luckily it turned out to be a fuse – it was replaced and the experiment continued.
- Start the vehicle. You will probably get a check-engine light (CEL) as the vehicle is confused: "Why isn't cylinder #3 firing? I'd better rich-out the mixture to compensate and let the driver know". The CEL comes on. If you get a relatively smooth idle, you're in business. If it won't start, won't stay running with throttle input, or if you have harsh vibration, then I'd go back to Step #3 and figure out which other cylinders are to be deactivated. This hasn't thoroughly been tested, so it may take some trial and error.
- If you do find a tolerable deactivation combination, the next step is to wire-in a switch somewhere inside the vehicle. I picked the rarely-used change holder to locate the switch, [Pic] as it was right where the wiring was coming through the firewall. The switch is a regular 2-lead variety toggle with basically an "on" or "off" setting.
- Get an idea where the fuel injector wiring is located. It's usually in bundle or follows the length of the engine into a harness or more wires [Pic]. Examine each injector's wiring (some removal of piping or a rubber sleeve may be necessary). [Pic]. Each injector should have 2 wires: a ground and a positive lead (my ground was black with a yellow stripe). I found the same colored wire for each injector and determined that this was the ground wire. You will be cutting the ground wire at each injector, but not yet.
- Get a feel for where your wiring will go. The next step is to drill a hole in the firewall to allow passage of wiring into the cabin of your vehicle. CAUTION: be mindful of what is on either side when drilling. Don't end up drilling into the brake master cylinder or something. Make some careful calculations.
- OK, so we have a location for a switch, a hole for the wiring and a plan. Now comes the fun part – wiring. I'd recommend using solder and electrical tape, or crimp connectors to do it right. Just twisting wire and taping it will fail on you at the wrong time, trust me on this one.
- Find the injector closest to the source of the ground [pic]. This will be our starting point and will provide a consistent ground. Cut the wire (leave enough room on either side to strip the wire and solder the connection) and route the source into the switch inside the cabin on one lead, through the firewall.
- Cut the negative cable to each injector. Tape-off the source wire ends and strip the wires from each injector's negative lead. Tie the leads together {diagram} and route the tied lines to the other end of the switch through the firewall. Closing the circuit results in normal operation. Flipping the switch stops the flow of electricity to the cylinders – cylinder deactivation
- Wrap tape around the wires through the metal hole or insert a rubber grommet into the hole. This is because the wires will most likely rub over time which can expose the wiring, short-out, etc. Use zip-ties or tape to seal the deal and keep the wiring away from moving engine parts.
Conclusion:
Possible uses for this setup could include wiring all cylinders to deactivate on deceleration and partial cylinder running for light-load cruise. Further experimentation and suggestions on this site involve a pendulum device to work in conjunction with the deactivation system.
Some concerns could include uneven wear, hot and cold spots, and running too rich. A fuel management system may be indicated to lean the mix. If possible, the other set of cylinders could be wired to a separate switch to allow for even wear (switch to Cylinder Bank "B" at the next fuel up so those cylinders get used. Then at the next fuel stop, switch back to Bank "A").
Further experimentation and additional devices need to be adapted for consistent operation. Good luck, and please report your results.
08-27-2006, 02:07 PM
You can take the rocker arms off those valves, eh?
08-28-2006, 07:36 AM
Tuggin at the surly bonds
Also, if you aren't disabling the valves, it seems you are essentially pumping air through those cylinders into the exhaust stream of the running cylinders. I can see O2 sensor responding and causing the ECU to enrichen to (over) compensate. If you do interrupt the valves, you'd solve that problem only to change the volume of air coming in through the MAF maybe causing the ECU to lean it out too much. Maybe.
08-29-2006, 07:14 AM
|V3|2D
i dont think its worth it. you still have all of that reciprocating mass. there is no savings in work.
12-22-2006, 09:19 AM
What if you were to merely block off the ports on the intake manifold by sandwiching a steel plate between the intake manifold and head rather than disabling the valves? In theory, this should create a vacuum at the intake after just a few revolutions, a vacuum is a lot easier to compress than atmospheric pressure, and there would still be no fluid flow to cause pumping losses.
Personally, if I could disable two of four cylinders easily I wouldn't bother with variable displacement. My car has 120 hp with 4 cylinders, and 60 hp would suit me fine.
12-26-2006, 01:25 AM
Originally Posted by Bruce
What if you were to merely block off the ports on the intake manifold.
You must block off both intake and exhaust ports and remove the spark plug.
Run the plug holes via threaded pipe into a heavily muffled air cleaner element to stop the sucking sound.
12-25-2006, 11:42 AM
Team GasMisers5!
My car has 135bhp with 4 cylinders, and I have been doing some interesting experiments.
I can use the LPG changeover switch to deactivate the injectors to two cylinders (I did this when trying to find out why my mileage computer wouldn't
recognise the injectors). I made sure the two cylinders I chose were ones that are opposite to each other, so that it isn't running more unevenly than it needs to. I don't think it does anything for economy (but I will check this when I get my SuperMID working), but some 'fun' things are:
(1) If you floor it at about 2500rpm, the turbo will go to full boost, but, there still isn't very much power. Then, if you switch back to 4 cylinders, you get a sudden massive power boost
(2) When at 4000rpm on full boost, the fuel is probably running at a 1:11 fuel/air ratio (quite rich). Normally, the hot partially unburnt fuel is just ejected from the exhaust, and has cooled down by then. However, if you have two cylinders pumping air, you get a certain amount of partially burnt fuel being introduced to nice clean air from the two deactivated cylinders. If you then suddenly let go of the accelerator, you get a nice flash + bang from the exhaust!.
None of the above are good for economy and have probably brought my tank averages down a bit  . However, I like the idea of the 'air springs' and may see if this has an effect in the future as well.
Miles displaced by e-bike since 1 Jan 2008: 62.6 ( 0 kWh used)
Hypomiler
12-27-2006, 02:02 PM
Air movement does incur a pumping loss, but the biggest contributor, what people talk about wrt gassers, is the pressure difference between the crank case and the closed cylinder as it moves down. At low load there is less air in each cylinder, which means the delta pressure between the crank case and cylinder at the bottom of it's stroke is significant, with the crank slowing significantly before the air/fuel is ignited because of this.
Gammy is right, although I don't think the exhaust and intake valves need to be blocked off. Just remove the plugs from the cylinders you don't want to run and make sure there is no fuel getting to them. Actually, leaving the exhaust/intake valves functional would be an advantage, since this lets in more air initially, so as the piston moves down there's already more air in, so less has to come through the spark plug hole which may reduces any losses from the smaller (but not static) pressure difference between cylinder/crank case while the piston is expanding, not to mention that more air will get in because the other two pistons need more air/fuel to do the same amount of work as four did during the same time span. All in all, I think you could easily see a 20% increase in FE if this worked. Do eeet!
Something else I just though of, get a normal gasoline PFI engine from the junkyard, and set it up for TBI/SAFI (megasquirt or whatever). This way, you can put a solenoid on each of the fuel injection holes that will open whenever you want. At a cruise you can fire one cylinder per rotation sequentially while opening the other cylinder's solenoids/cutting fuel to them. I'm not sure if this would result in some funky vibrations, but since you can fire a different cylinder/combo of cylinders each engine cycle, maybe you could work something out for best fuel efficiency/least vibrations.
Anyway, as for your first experiment, cutting fuel to two cylinders, you should see some increase in mileage. Removing the injectors from those holes should net a larger increase in efficiency. If you had a nice long stretch of road next to a gas station where you could go at some low speed in top gear this would be a great experiment, checking the increase in efficiency after fuel deactivation and then after pulling the spark plugs.
12-27-2006, 08:06 PM
Intuitively that seems all wrong.
Think about it this way. Diesel engines are already BTU corrected by the EPA for mpg figures. And in the same car with the same transmission diesels get ~30-40% better efficiency, partially because compression ignition is a little more efficient, but mostly because the throttle is always wide open. In fact, on most there isn't a throttle. Diesels always suck in enough air/exhaust gasses to fill up the cylinder totally, so when the cylinder is at the bottom of it's stroke, the pressure in it is about the same as the crank case pressure. But in gassers, there needs to be a correct air/fuel ratio, so there can only be so much air drawn in, which is metered by the throttle, cam duration, and valve size. Since most of the time, the car needs much less than full power, there isn't a full amount of air drawn into the cylinder, and when the cylinder is at the bottom of the stroke, the pressure in it is much less than the pressure in the crankcase. The entire time it was traveling down, if the pressure is greater in the crankcase, then this is effectively resisting the cranks forward momentum, and reducing efficiency.
Going to the variable displacement idea, if the engine only needs 20hp at 65mph, by only using say, four out of eight, the throttle can be opened wider since those active cylinders need twice as much air to burn twice as much fuel (or remain closed and act as springs if vibrations are a problem), and since the other four aren't burning any fuel, they'll suck in twice as much air too, w/o any probs, and the difference in pressure between the cylinder/crankcase will be much smaller with more air in all the cylinders. I think the biggest hurdle was making the transition and operation with fewer cylinders smooth/reliable.
One more example is the Atkinson cycle. Toyota keeps the intake valves open longer so that a larger portion of air can be pulled in, then closes them once the cylinder has moved up and pushed enough air out for the air/fuel ratio to be correct. By letting more air in the pressure difference between the cylinder/crank case is smaller, so less negative work is done.
Originally Posted by Wikipedia
The Atkinson cycle may also refer to a four stroke piston engine in which the intake valve is held open longer than normal to allow a reverse flow of intake air into the intake manifold.
Your engines must run on different principles than mine!  The intake valve would NOT be open longer as it is controlled by the cam- on non-variable cam timing engines there would be no change. I don't think this pumping loss thing is registering yet... or the "air spring" effect of a closed-off cylinder either. Why don't you pull your plugs, un-plug your injectors, test your FE and get back to us?
That's a typo, I meant the intake valve would let in more air because the throttle is open wider. To allow the two operating cylinders to make double the power you need double the air so you could go the same speed compared to all four firing at that speed. Bleh, that's a mouthful. I'd love to screw around with this, but I only have a carb'd pickup and a diesel that are mine to play with.
I'm thinking if I removed two of my injectors the vac leak would screw up the "functioning" cylinders- it probably wouldn't even start!
Huh? I meant that as an experiment with an engine retrofitted with throttle body injection. You are using MPFI, one injector per cylinder, correct? The point of my brainstorm was to have solenoids in the injector holes and fuel/air coming from the TB to allow for selective cylinder deactivation in a certain pattern. All you should need to do is disable two of the injectors so they don't fire, which should be the largest increase in efficiency since you'll be cutting pumping losses in half. And by removing the spark plugs from the two cylinders where fuel is deactivated, this allows the pressure in the cylinder to always ~equal the pressure in the crank case, even if you're at a speed where the other two cylinders aren't drawing as much air in as they could. The first step should increase efficiency the most, and removing the spark plugs should help a bit more.
12-28-2006, 12:16 AM
I think theclencher's take on mileage increase is accurate. The EPA tests have the car bouncing around in terms of speed, so who knows how often DoD is actually activated. I'm guessing that a four cylinder with ghetto DoD could see as much as a 20% increase cruising at 45-55mph because it'll always be on unlike commercialized systems by GM, etc... that are designed for the overall driving experience.
From one of the articles Gammy posted
EPA tests show a 6% to 8% improvement in fuel economy, but real-world highway use promises even larger gains.
