New Charger Aerodynamics
I just bought a 2007 Dodge Charger. I know not the typical car here. For good mileage I will drive my Scooter or CRX.
Here are a few things I found intersting on the Charger. It has a belly pan under the motor. There is also small lip seals on the front doors to help eliminate the seams. It a coefficient of drag of .33 https://en.wikipedia.org/wiki/Automob...g_coefficients So they tried to clean up the aerodynamics then just overpowered it so it still gets crapy meilage https://www.fueleconomy.gov/feg/2008c...umn=1&id=23609 |
.33 still leaves room for improvement....
The Impala with the 3.9L V6 has more power than your Charger and gets 18/28 as opposed to your 18/24. The problem with your Charger isn't that it has too much power, it's that it has that 3.5L Chrysler V6.
2007 Impala Old numbers 20/29 New 18/26 3.9L 233 HP CD .33 200.4" exterior length 72.9" exterior body width 58.7" exterior height 3637 Curb weight 2007 Charger Old numbers 19/27 new 17/24 3.5L 250 HP 200.1 " exterior length 74.5 " exterior body width 58.2 " exterior height 3727 Curb weight By the way the Impala was the other car I was looking at getting. |
I'd say .33 is pretty good considering that the front end looks like a parachute, and the car keeps getting wider towards the rear. I'm not dissing it, the same look is found on the new Camaro that I love, just saying .33 is great considering how un-slippery the car looks.
Damn, it is VERY slippery considering its shape and masculine humps!!
I really never thought it would be that low on that car, well, then I guess my next mod is door seals! (Not kidding actually a good idea :) ) |
i disagree with you guys. the feminine humps(or should i say hips) have a very smooth contour that does taper back. dont get me wrong, it is still very much a "manly" car, it just has hips and dudes dont. we are talking about a couple inches here and the real beef with it would be frontal area, not so much .cd. the rear windshield has a very nice taper as well.
i guess the sad thing is any aero mods that would significantly improve the car would make it really ugly. the only thing that wouldnt ruin the cars looks would be an upper grill block and a modification to the bottom of the rear bumper to decrease the low pressure system behind the car. |
I plan on blocking the lower part of the grill next. I figure it was designed with enough airflow for the HEMI so I should ok with the V6. I will watch temps on my scangauge. Winter is coming so I should be fine but I will need to watch it in the summer.
https://www.fuelly.com/attachments/fo...e73fc61001.jpg |
