-   -   VTEC solenoid/pressure switch - same for all VTEC motors? (https://www.fuelly.com/forums/f10/vtec-solenoid-pressure-switch-same-for-all-vtec-motors-9755.html)
Cosworth 08-18-2008 01:43 PM
Could someone with expertise in VTEC parts interchange-ability answer the following question?
I have a '92 Si that need a new VTEC solenoid valve/pressure switch combo. I've been looking for a used one, and it seems that maybe any one from any VTEC motor will work for my d16z6 motor. Is this correct?
VTEC Solenoid valve/pressure switch from VX = Si = EX = GSR = SiR = d15b??
:confused:
TIA!
thisisntjared 08-19-2008 08:59 AM
i dont believe they are the same but i could be wrong. ht didnt yeild any results??
Cosworth 08-19-2008 02:11 PM
I was going by the manchester catalog... it seems that the valve and switch have the same part number, but mounting pieces are unique to different motors... I think. I just need to get a confirmation from who's done swaps.
78si 08-19-2008 05:35 PM
The housings have a different bolt pattern.
GasSavers_grasshopper 08-19-2008 07:18 PM
All d-series vtec solenoids from 92-95 civics will fit your car. 96 and up have a different bolt pattern.
Cosworth 08-20-2008 01:43 PM
Cool. Thanks for the info. So, VX, EX & SI from '92-'95 should all work, right?
That gives me a lot of options. Thanks! :thumbup: :thumbup:
