-   -   Throwout bearing & EOC (https://www.fuelly.com/forums/f8/throwout-bearing-and-eoc-9311.html)
theholycow 07-08-2008 03:29 PM
I only have a vague understanding of the clutch throwout bearing, but I had a thought. It is said that you should not spend a lot of time with the clutch depressed, even at a dead stop, because you will prematurely wear the throwout bearing.
If the engine is off, does the throwout bearing not wear and not spin? Can I stay on the clutch pedal during EOC if I want to, instead of shifting to neutral?
R.I.D.E. 07-08-2008 03:39 PM
Yes. Throwout bearing is not rotating when engine is turned off.
regards
gary
