-   -   aero turbine performance exhaust (https://www.fuelly.com/forums/f8/aero-turbine-performance-exhaust-9254.html)
collegekid01 07-02-2008 08:08 PM
Has anyone herd of these? I stumbled upon these while searching the net one day and it seems legit. There could def be some extra fuel savings here guys...
check out the video clip:
https://www.aeroexhaust.com/aero_perf...e_exhaust.html
GasSavers_RoadWarrior 07-03-2008 02:55 AM
Sounds convincing, muffler design has been stuck in perforated can, or helmholtz resonator mode for years, which if you get a well matched one, it can do wonders.
However, they could just be on a "Design a better fart can and the ricers will beat a path to my door" kick, but $123 on sale sounds fairly decent for an SS muffler.
GasSavers_RoadWarrior 07-03-2008 03:02 AM
Hang on a second... these sound like just a spiral path helmholtz type thing.... only I guess the path length is a little longer with the spiral, and I guess instead of doing a right angle split the aerofoil thing is more efficient...
collegekid01 07-03-2008 10:34 AM
they seem convincing enough to me. you can even get their sedan version for 89.00 and it comes with a lifetime guarantee. The thing is all stainless steel so it should hold up.
ShadowWorks 07-03-2008 11:30 AM
The website is down, I found this patent for a true noise cancelling vortex silencer.
https://www.freepatentsonline.com/7073626.html
https://www.freepatentsonline.com/7073626-0-display.jpg
A muffler of this type manages without the use of sound-absorbing material. Neither lining pads on the inner walls of the housing nor insulating elements consisting of sound-absorbing material between the deflecting elements are required. Just deflecting the flow with the aid of the guiding elements in the manner of guide vanes causes sound to be absorbed, in which case sound vibrations cancel one another out. This is achieved especially by different setting angles, in particular if the guiding elements of adjacent, disk-shaped bodies are in each case preferably angled in an opposite direction to one another.
fowljesse 07-04-2008 12:09 AM
That looks restrictive, but if it really cancels noise, it would be worth it for most. Flowmaster has done alot of research on this, and IMO, make the best muffler.
