-   -   1996 DX ..what can I do? (https://www.fuelly.com/forums/f8/1996-dx-what-can-i-do-9178.html)
grey 06-28-2008 02:22 PM
This is a Mazda Protege with 1.5.
I see this site is almost all Honda's, but hopefully some of those guy's can relate to Mazda setup as well.
One thing that interests me is "lean burn". I think my car is pretty much stock. "Lean burn" was a term used by Mazda to describe a variation of this engine sold in Japan. Some say the same setup was sold in US in '96.
I have a scanner that will print some information here, so what operational data would you need to see to tell me about how this engine controls itself? I think it behaves well, but I would appreciate your thoughts.
Thanks
GasSavers_RoadWarrior 06-28-2008 02:46 PM
I'm thinking in Ford here, due to a lot of protege stuff being similar to escort stuff, but a scanner I borrowed was able to tell me injector duration hooked to the Escort. So, if'n you've got that, that should be an indication.
grey 06-28-2008 04:05 PM
I think the same engine might be in some escorts, but the ignition is different, among other things. I think that is correct.
Scanner shows obd2 ISO mode $10- Fuel trims, but not pulse width.
This is an actron scanner.
grey 06-28-2008 04:10 PM
this was at idle after a long drive
MIL STATUS OFF
ABSLT TPS % 9.8
ENG SPEED RPM 693
CALC LOAD % 15.6
MAF FLOW GR/SE 1.63
COOLANT ?F 192
IAT ?F 82
IGN ADVANCE DE 10.0
ST FTRM1 % 25.0
LT FTRM1 % 1.5
VEH SPEED MPH 0
FUEL SYS 1 OPEN2
FUEL SYS 2 N/A
O2S11 V 0.000
ST FTRM11 % 25.0
O2S12 V 0.835
OBD2 STAT US
grey 06-28-2008 04:27 PM
here is what happens when a new 02 sensor is needed.
Global OBDII
Non OBD Freeze Frame
Frame 1 Mod $10
TROUB CODE P1170
ENG SPEED RPM 2383
CALC LOAD % 25.4
COOLANT ?F 192
ST FTRM1 % 0.0
LT FTRM1 % -3.4
ST FTRM3 % -100.6
LT FTRM3 % -100.6
VEH SPEED MPH 42
FUEL SYS 1 OPEN2
FUEL SYS 2 N/A
check out the -100% fuel trim. Dont know what that means...
The 02 sensor was going way lean ( 0 volts) for several seconds at a time
theholycow 06-28-2008 05:36 PM
You won't get fuel rate from OBDII. If you want fuel injector data, take a look at the fuel rate monitor link in my sig. It's very interesting to watch live while you're driving.
GasSavers_RoadWarrior 06-28-2008 07:07 PM
Ah right, that was an OBD-1 scanner I had, might have been in a ford specific program too, KOER regime of the EEC-IV self testing procedures now I come to think about it.
theholycow 06-29-2008 03:27 AM
Well, to be 100% accurate...while OBDII itself won't transmit fuel rate, there could be manufacturer-specific extensions to it that will, but they'll require expensive specialized equipment to read, instead of a relatively inexpensive ScanGauge or ELM327.
suspendedhatch 06-29-2008 07:10 AM
Look into swapping in the JDM lean-burn motor and ECU. Maybe you can get close to Civic VX numbers.
grey 06-29-2008 11:31 AM
That may not be possible or even necessary
I would like to know what some this scanner data means:
ST FTRM3
LT FTRM3
ST FTRM11
Maybe there are ways to convert the "economy" package to lean burn.
