Fuelly not posting to facebook after deactivate and reactivation of Facebook account.
Yesterday I had cause to deactivate my Facebook account and reactivated it this mourning. I've verified Fuelly is still listed as a application on Facebook and on Fuelly in settings Facebook shows as active. I hit the reset link also next to my Facebook id on Fuelly settings page and still on Facebook the 1st fuel-up on my new car has not posted to Facebook. Please can a administrator on Fuelly check to verify my Facebook function is working and if possible push that one and only fuel-up done so far on new car to Facebook. |
The key to resetting your Facebook/Fuelly connection is removing it from Facebook first. So you might try that, then do a reset here.
We don't have a way to push updates out to your wall after the fact, so you might try adding a test fuel-up to make sure the connection works after you remove and re-add Fuelly. (Then you can remove that fuel-up from your wall.) |
That fixed it.
