FITV port sucking air
tracked the surging idle problem to a possible solution - FITV. the port in the throttle body is sucking air.Manual says to replace it. When I block the port the surging continues. Is there another problem or will blocking the port not eliminate the problem?
Can this part be fixed? |
what's your year/make/model/engine? might help...
95 civic ex coupe vtec 1.6
