-   -   from 27.87 MPG to 71.43 MPG!!!! (https://www.fuelly.com/forums/f8/from-27-87-mpg-to-71-43-mpg-8940.html)
mirinae 06-13-2008 12:28 PM
Right then, I've got a 1969 Landrover Series 2a 2.25L Diesel. I put magnets on the fuel line and increased the mileage on a set 17 mile route at a steady 40mph to 27.87mpg. I then constructed the single cell system and fitted it. My first run was with the bubbler closed and on the set run increased my mileage to 28.84mpg. A positive start, but I felt that the engine was being starved of HHO. I then reduced the length of the two feed pipes going to the closest point on the air intake manifold to 4 feet each from five feet and opened up the bubbler to allow a moderate amount of air through. I then ran the same run (each run took 35 minutes) and compared the results. My 39 year old Landrover did 71.43mpg!!!!
In truth, I was hoping to achieve a modest 40mpg but this is unbelievable!!
Water Car Run on Water+Fuel
GasSavers_Kraig 06-13-2008 12:39 PM
Details of what you did?
R.I.D.E. 06-13-2008 01:15 PM
Think I need my boots on.
regards
gary
Mayhim 06-13-2008 01:20 PM
Can't we rig something up that gives these guys a shock through the keyboard when they try to post that stuff?
dkjones96 06-13-2008 01:34 PM
Sometimes I wonder if this type of 'advertising' or 'marketing' actually ever works.
It had to somewhere right? Maybe?
kamesama980 06-13-2008 01:44 PM
aren't there mods with power to lock/remove threads?
AMX 06-13-2008 01:50 PM
Sure bud, we're not that gullible.
slogfilet 06-13-2008 01:53 PM
Yep, sure is.
1cheap1 06-13-2008 02:15 PM
mirinae, commit suicide and take the secrete with you.
thisisntjared 06-13-2008 03:48 PM
i bet you did....
