-   -   mileage took a dive (https://www.fuelly.com/forums/f8/mileage-took-a-dive-8376.html)
Hateful 05-13-2008 01:32 PM
mileage took a dive
I thought I was doing so much better as my ScanGauge read 37mpg for this last tank and also showed that I used 12 gallons. I went to the station and pumped really slowly as I had read about here. To my surprise, it took 13.28 gallons to refill my take and knocked my mileage below 34mpg. Something is wrong; time will tell. I've used 1/4 tank since then only getting 33mpg.
kamesama980 05-13-2008 01:45 PM
um... oh no? just gonna complain or got some ideas about why?
theholycow 05-13-2008 02:31 PM
If you pumped slower than usual, you pumped fuller than usual. Slower pumping is like topping off.
Hateful 05-13-2008 03:19 PM
This is what I hope happened. I've never gotten over 13 gallons into the tank on a refill before.I looked up the tank size and it's 14.1 gallons; all those times I worried about running out for nothing. The only different thing I did this tank was more pulse and glide,which I thought helped. I just got 38mpg coming back from the grocery store( per ScanGauge). We have had some wind and rain lately and I did have to go into some shopping mall parking. That could account for the bad mileage on this tank so far.
Hateful 05-23-2008 10:43 AM
Looks like it was the slow pumping top off that threw the mileage off. I topped it off again at about the same miles and got 35.8mpg; about what I had been getting recently. The ScanGauge was off again, but in the opposite direction; showing 32.9mpg. I'll have to keep on topping off to keep my gas log correct.
JESSE69 05-23-2008 10:56 AM
Sometimes I think the Chevron station I fill up at changed their calibration and charge me more for less gas!
Hateful 05-23-2008 11:01 AM
I usually run my tank pretty low,so if it ever goes over 14.1gallons. I'm calling the Dept of Agriculture division of weights and measures.
waddie 05-23-2008 11:25 AM
I filled a 5 gallon gas can for the mower at the local country station a few years ago and they tried to charge me for 8 gallons. The pumps were WAY off.
1cheap1 05-23-2008 10:32 PM
Since i started a log on this web site and read others logs it seems the mpg will go up and down some what until we post many tanks to get a good average.
1993CivicVX 05-23-2008 11:03 PM
I had this suspicion once of a Cumberland gas station (I believe it's Gulf gas) I was so sure of it in fact, that I got a gas can and filled it up to the 5 gallon mark and logged how many gallons it took (about 5 gallons) and then emptied the gas into my car and did the same thing at the station across the street, filling the gas can up to 5 gallons again which was also a very similar number. So, to my disappointment, I had to drop that hypothesis.
