CRX HF lean burn
I should probably look to posting this question on a Honda board, but since they're mostly ricers I figured I could at least get away with asking it here.
Well, I was following this thread for a bit: https://crxcommunity.com/viewtopic.ph...ffe26e1d1c7750 ..and I thought about how the Civic VX engine (D15Z1), although much more powerful than the CRX HF engine, still uses so little fuel. I then wondered, without doing the HF to VX engine & ECU swap, could a compromise be reached with the HF engine? That is, what would it take to get a CRX HF to be lean-burn? Obviously the car would still lack the V-TEC and horsepower of the VX, but it would certainly save more fuel if it had the lean-burn advantage. Any thoughts? Could a VX ECU be modded to work? |
lol, or I suppos I could do just a little bit of research first, to prevent me from looking like an entire ***.
I guess I should omit the "lean-burn" phrase, since that is apparently reserved for an engine that keeps 4 intake valves at bay, while using just one intake valve per cylinder during times when only minimal power is required. Instead what I would like to propose is the feature of the VX that allows the engine to shut fuel to the cylinders off when the car is just coasting, since some of us don't like shutting the car off every time we coast. I think every car on the planet should have a way of shutting fuel off when coasting for significant periods of time. |
decel fuel cut? like leave it in gear and use less gas, or neutral coast fuel cut? the latter, just use the key. the former is a little more complex.
It would be wiring, ECU and a few sensors like the $170-$300 O2 sensor... but this is a good question! maybe throttle position sensor? I think the 2nd generation crx hf had very simaler fuel injection set up as the VX does, 1st generation crx hf have a carburator of course and are already basicly a lean burn with carburator.
As for lean burn, this is going to be something difficult to apply to the HF. The problem is that the ECU has no provisions for it. As long as it is running in closed-loop mode, it is going to try to maintain a stoichiometric mixture. And any attempt to lean things out beyond the ability of the ECU to correct is going to make things lean all the time - not good. As for shutting off fuel to the cylinders while coasting, this is actually a typical feature of pretty much ALL EFI systems. Your HF probably already does it. |
I know that my 1985 crx hf cuts fuel while coasting in gear as long as the engine is still above a set RPM, my 1983 honda civic also does this, you can clearly see this in the wiring diagram for that car, I can dubble check but I'm pretty sure that my 1973-78 civic shop manaul also shows the fuel cut solinoides, 3-4 of them on the carburator allowing it to compleatly cut fuel, and a vacuum switch on the intake manifold that trips them when the throttle is closed and the engine is reved.
My HF cuts the injectors at above 1200 rpm with the throttle closed when it's warm, 1500 when is cold. You can feel it happen when the rpms drop below you can fell it surge forward slightly when the injectors open
I think you could simulate a lean burn system on a car other than the VX pretty easily, but I am not sure how well it would work, or how hard on the engine it would be.
If I was going to try it, I would buy an Innovate Motorsports Wideband O2 sensor and controller. These controllers usually come with two sets of analog outputs, that can be programmed to simulate a narrowband O2 sensor, such as the one used on the HF. However, it would be very easy to set the controller to output one signal that had the narrowband crossover point at 14.7/1 AFR, and the second one at something higher, like 15.5-16.5/1 AFR. Then it would just be a matter of switching which one of these two signals fed into the O2 input on the hf ecu. When it was set to the higher AFR input, it would use the closed loop mode to attempt to hit this AFR instead of 14.7, which would result in a "lean burn mode". It is possible this would just confuse the ECU, and cause a CEL, though. |
For in gear fuel cut, I checked the shop manuals and the 1973-77 1.2L and 1.3L civics had fuel cut over 12mph with a warm engine, good oil presure and high manafold vacuum, those engines do not appear to be cvcc engines, the 1977 cvcc engine might be the first cvcc (lean main mix with a rich mix next to the spark plug giving an overall leaner mix) that also had fuel cut while going over 12mph with high manifold vacuum, and it appears to be 3 solinoids that were triggered that cut the fuel.
does anyone know if a vx ecu would work in a 2nd generation crx? are they simaler enough that it would plug in? |
