-   -   d15z1 into a Del Sol?? (https://www.fuelly.com/forums/f8/d15z1-into-a-del-sol-7232.html)
ravenrollercoaster 01-07-2008 07:30 PM
I allways liked the del sol but I would like a higher MPG car. Is it a straight forward swap.. Trans engine ECU and Harness.. There is an SI close to me that is pretty cheap.. I was thinking about picking it up driving it till it dies and piecing together the swap.. while I am still driving it.. LMK
thanks
jim
mrmad 01-07-2008 08:03 PM
I've always like the Del Sol as well, you'd end up with a cool car.
Danronian 01-08-2008 06:23 AM
It would be bolt-in. If you bought the model with the vtec d-series motor. You would only need to run the wiring for the 5-wire o2 sensor. The rest of the wiring would be done already.
The civic/delsol share identical dimensions for the drivetrain.
Matt Timion 01-08-2008 06:24 AM
Dont' forget the EGR control box... that's one or two extra wires.... so you'd need to run 3 wires total.
That's assuming you get the SI (which has a vtec engine).
I say do it. :)
first350 01-08-2008 06:33 AM
you can read through my build for more info...I found small differences throughout the build/swap.
I have a '92 DX and swapped in a '95 VX.
https://www.gassavers.org/showthread.php?t=5929
ravenrollercoaster 01-08-2008 08:13 AM
ok thanks fellas.. you guys are awesome I am gonna do it if I pickup the del sol I will keep you guys updated...
thanks
again..
Also The trans is a si trans right I will need to swap that out to get full potential right??
Matt Timion 01-08-2008 08:24 AM
thanks
again..
Yes, swap in a VX/CX transmission.... but also remember that you can sell your Si engine and trans for a nice little profit.
