92 VX only getting 33mpg
----Edited to update progress as i check things, so people don't have to read the whole thread - last edit 1/31/08---
Started with 33mpg Best tank so far with california ECU 43mpg Swapped in Federal ECU and got 49 mpg Background info: 90% highway driving, 100 miles a day Average speed is 55-65mph I don't drive like a hypermiler, but i do get passed alot No CEL on It is a california car, has the l00 ecu but has a 5-wire o2 sensor. Apparently this happens sometimes on the 92 models. So far i have changed/tested: Switched to VX rims and 175/70r13 tires losing a total of 44lbs Compression tested 170-180 all cylinders Replaced zfr5f-11 spark plugs with zfr4f-11 Front calipers not dragging One of the rear drums had a little resistance, will check further Checked O2 sensor, readings posted below Checked and adjusted timing Swapped in federal ecu So far on the list to do is: Get alignment Check EGR (my egr ports on manifold look to be welded/sealed up, is that normal?) Check vacuum What else should i check? |
My favorite tire size calculator:
https://www.wickedbodies.net/Tire-Size-Calculator.htm Completely aside from rim size, if the overall tire diameter is different from that of the original spec tire then your speedometer will be off. Larger tires would mean you've actually driven further than the odometer shows. So use the calculator to check your current front tire size vs. the original spec size. It will show you the % difference. |
Check your engine vacuum at idle then slowly increase it to 3000 rpm.
If you don't have at least 20 inches of steady vacuum under these two conditions, then you have a compression issue in one or more cylinders. An exhaust gas analyzer would help to confirm if your VX is running super rich. My 92 VX holds 24 inches of vacuum at idle and at 3000 rpm. I'm getting about 42 mpg but I live in Michigan and it's been cold lately. I average 44 mpg over the entire year. You should be able to achieve this easily. I'm running the 175/70R13 size now on the OEM VX wheels and have lost 1 mpg or so from what I had with the stock 165 width. I drive 70% highway at 70 mph. |
That is my tire corrected mpg.
I will try and test the vacuum later and do a compression check. Thanks. |
Haven't got a chance to check anything yet, but i did pick up some VX rims. Spent all day stripping the green paint off of them, I'll either paint them white to match the car or if I'm feeling bored try and polish them.
The car seems to run just fine, except for the low mileage. The only thing is it makes a little noise with the clutch out and the car in neutral, goes away when you press the clutch in. Not sure if that is normal or not though as this is my first honda, and first front wheel drive car. |
You might have a bad bearing in the transmission. It is usually one of the two ball bearings on the mainshaft that goes bad eventually - especially when the axle seals leak. Don't let it go for too long or the bearing may fail - which will trash the tranny altogether. I was lucky to catch it before the cage broke. The ball bearings were all gouged up. The bearing issue should not affect the mpg issue though.
I replaced the bearing myself but it isn't a easy one man job. The toughest job is pulling the tranny from the engine. The dowel pins hold the tranny pretty tight to the engine. I did this with the engine/tranny still in the car. You might as well put a new clutch in while you've got it apart. |
It could also be something like a caliper that is dragging.
Or a wheel bearing that is going bad and dragging. Also check your alignment and all related suspension components. How fast are you driving on the highway? I get the best mileage at 60mph...anything over that and the mileage drastically decreases. jadziasman...which bearing did you replace? You make internal transmission work sound like a job for a novice, which to my understanding wasn't? lol. Can you provide a little more info? I've got 230K+ miles on my transmission and am getting ready to do a clutch job, and if it's something a mechanically inclined guy can do, please let me know as I wouldn't mind replacing any bearings that I can access. |
As for your mileage, this doesn't sound right. I get the same mileage with my CRX that is powered by a 200HP JDM ITR motor. And I drive that car 80+MPH on a daily basis. |
I will be getting it aligned again after i switch to the vx rims and raise up the suspension a little, its currently on eibach coilovers and at about 3" lower than stock. I know my camber is off. |
