CRX HF (D15B6) Valve clearances
Does anyone know the valve clearances for a CRX HF? My manual only covers SOHC 16V engines. The valve clearances for these engines are 0.007-0.009" for the intake valves and 0.009-0.011" for the exhaust. Does the 8 valve D15B6 has the same clearances, or something else?
I am pretty certain that the clearances are exactly the same. If you ever look at a HF head, next to a DX, the only difference is that they didn't put in the fourth valve on each of the cylinders. The head's look identical, otherwise. On mine I just used .009 for all of the valves.
Thanks Gary, that's kind of what I thought, but just wanted to be sure.
