Autospeed Beetle Article
What do people make of this article here?
The relevant commentary from the author, Julian Edgar, is here: Quote:
If the rear surface of a car will stall like an airplane wing, it seems as though this fits rather well. Especially if you consider that angle of attack is measured as the angle the chord of an airfoil makes with respect to the oncoming wind. Note that the chord is the line from the leading edge to the trailing edge of an airfoil, and so in a typical airfoil or wing there will usually be a more extreme angle to be found taking a tangent to the rear upper surface of the wing compared with the the chord line. This means that if a wing is just stalling at an angle of attack of 16 degrees, the most extremely angled tangent at the back of the wing (analogous to the boat tail of a car) will be higher, maybe 18 or 20 degrees or so. This agrees well with the boat tail angles of very low drag concept cars and hybrids, which can be assumed to have pushed this to the limit through trial and error. So if you have a look at the pictures of the rear of the beetle, there are also some tufts that aren't agreeing with Julian Edgar's explanation and appear to be in turbulence higher than the artist's interpretration of where turbulence is occuring. In fact, the third tuft from the top of the window is pointing back towards the front. Perhaps there weren't enough tufts to get a good idea of what is happening back there. But maybe I'm wrong. It's where our mental models are challenged that we learn something new. |
you might be on to something here
if drag at the rear is caused by "stalling" due to a to extreme angle that would bring vortex generators back in perspective... |
Yes, there are a few disagreeing tufts in that photo (mainly the third tuft down photo left on the rear windscreen and the tuft in the middle bottom of the hatch, left). For the windscreen one -- I can't explain that, there could be external forces or a pressure wave interfering. For the one just left of the rear fender on the hatch, that looks like an interaction with the flow coming over the fender - note the tuft just above it, it is being sucked to the right (towards the fender), possibly indicating a low pressure (faster flow) zone. In general though, the straight tufts on the bottom portion of the hatch are very telling. If the flow has stalled/separated - the odds of getting a straight tuft on a photo like that are very very low. It's very likely separation doesn't occur at the same point (hatch lid), but it does appear to get pretty far down. Perhaps the bottom of the glass :) I think the person that runs this site is a member on GS... There's some good information in there :) |
I don't believe that tufts tell the whole story about what is really going on. Given the apparent high degree of attached airflow over the back of the car, allot of energy is actually being put into accelerating the air. Similar to wing flaps which are designed to extend the attached airflow, providing additional lift, that comes at the price of additional drag. It's not the stalling that causes the drag, but rather the smooth airflow in lieu of it!
This may seem counterintuitive to say, but going back to the simple example of placing one's hand out the window into airflow, the effect of extreme unstalled angled of attack vs. a stalling condition can be felt as reduced rearward pull at the initial point of stall. In other words, the roofline of the Beetle is TOO CLEAN. It could benefit significantly by inducing stalled airflow much earlier over it's profile - something I believe that they actually addressed with that silly but useful little motorized spoiler on the Turbo models. ;) |
I suppose if the rear of the car HASN'T stalled at that point (which I'm not 100% convinced as per the photos), at least you do have a situation where you are changing the direction of the air to be pointed downwards, and this will give you substantial lift and cost you energy to do so. Most of the top strata low drag cars (not including solar, because they operate outside of usability constraints and can do a proper extended airfoil) are kamm backs, with the end of the kamm back pointed near horizontal. I suspect that this does two things, by getting the air leaving the car to be moving the same direction it was as it found the car. 1) It minimizes lift by not sending the net flow of air that the car meets in a downward direction, making handling fairly stable, and 2) since it isn't generating lift, it's not costing energy to do so. If this wasn't the case, the wake could be made a bit smaller with the same vehicle length by keeping the most extreme angle achievable with flow still attached, right until the very end of the vehicle as per the beetle. The fact that most don't is pretty telling, and even the "exception", the EV1, has the bottom coming up to the same degree and hence is still leaving the net mass of air behind the car going directly behind (although slowed a bit because of friction). Quote:
it's a neat wing, but it will never "fly" with mainstream. people don't want efficient cars. they want fast powerful looking cars with moderate to low efficiency.
It should have read: "That's to say the ideal rear end will be shaped like the rear portion of a foil." Quote:
What we really need is more photos :p Or tunnel testing smoke screen photos :) Just curious, do you think pressure lift is more significant than reaction lift? |
Investing in fuel efficiency modifications and driving is something that already has a fairly short payback period. If the fuel price goes up like it's doing now, and keeps going up, it's all gravy. |
What we really need is more photos :p Or tunnel testing smoke screen photos :) Quote:
I was thinking about this the other day, for a long time, Bernoulli versus Newton. Both should be a different method of looking at the same thing. Ultimately the net force acting on the car should be the sum of all the pressures on the car at different points. i.e. an integral over the surface of the car of the pressure. It can't be any other way. Newton is useful to think of because if you can figure out where you are sending the air, you have a good indication of where your object should be pushed. Someone here has a picture of the big swirl behind an airplane in the cloud. It tends to be easier to visualize with laminar flows without a stall, because you can think of a big body of air moving a particular direction. Although I guess in a stall you are actually causing a mass of air to be moving in the direction that you are going (if you have ever walked by a semi traveling at speed you will know what I mean), and conservation of momentum means that your airfoil (or car) must be slowing down as a result. After a certain point behind the vehicle, everything decays into turbulence and the kinetic energy you have imparted to the mass of air behind the vehicle remains in the form of heat (which is just atoms of air moving around on average somewhat faster, but every which way). I still have a bit of an aversion to Bernoulli, but that's just because of the grade school science textbooks that mangle the explanation with a wing, arguing that because the top of a wing has more distance for air to travel, that the air pressure is lower and you get lift. The logical extension of that is a wing shaped like a triangle with the base at the bottom, because then you have even more distance to travel and so more lift. And that's obviously wrong. But in the end, there are two truths. Momentum must be conserved (i.e. send a mass of air going one particular way, your airfoil/car will be sent another, i.e. you want to leave the air just as the car found it for low drag), and the integral of pressure over the surface of an airfoil/car must be the net force (due to air resistance, every net force I'm talking about above is only regarding air resistance obviously). |
