-   -   An Ideal Cruise Control (https://www.fuelly.com/forums/f8/an-ideal-cruise-control-6568.html)
2TonJellyBean 11-02-2007 07:58 AM
A "Load" based cruise control for economy.
https://www.everytime.cummins.com/every/misc/load.jsp
rvanengen 11-02-2007 08:18 AM
Wouldn't that make a cool option to use when the normal cruise control is engaged on a car with an automatic?? :D
Imagine setting "Ultra Economy" for when you are really out on the freeway and can let your car slow signifcantly w/o getting killed by other drivers when approaching small grades to keep the engine in its efficient band?? :thumbup:
skewbe 11-02-2007 09:00 AM
https://www.gassavers.org/showthread....uise#post65028
(Man, this new avatar of mine is painful even for me, I'll have to change it tonight
https://www.gassavers.org/image.php?u...ine=1194004952
rvanengen 11-02-2007 10:54 AM
(Man, this new avatar of mine is painful even for me, I'll have to change it tonight)
scanned the thread....anyone implement it yet except as a monitor?
skewbe 11-02-2007 04:54 PM
Nope, just saying "that would be cool" too. It's a good head start on a working model though if anyone wants to do more than say "that would be cool" :)
rh77 11-02-2007 06:11 PM
I've developed one...
Kinda.
It's a throttle-limited setup, which uses load on hills quite well. The design simply blocks the throttle that the cruise-control unit pulls.
The CC pulls the throttle cable similar to the foot pedal. I blocked the action of the rotating cam that pulls the cable -- basically governing the maximum throttle position. The TPS setting is around 20% maximum via CC.
Using it: set the cruise for 60 mph, for example. The car will generally hold the speed until the load overrides the throttle, then you scrub off speed and load it up. It works well if you're exhausted and have a long highway drive ahead. Then, the unintentional Psychology of not holding speed on hills is left up to the device and not your foot.
RH77
rvanengen 11-04-2007 06:41 AM
Kinda.
RH77
How has it worked for you?
