-   -   Measure Fuel usage using DVM (https://www.fuelly.com/forums/f9/measure-fuel-usage-using-dvm-6417.html)
cwa 10-17-2007 10:46 PM
I have connected one of the Injector Signal (& GND) to DVM (Digital Volt Meter) and here are the results.
Park = .47 V - .51V
Neutral (idel) = .48 V - .52V
D (With Break) = .49V - .54V
Neutral (2500rpm) = .95V - 1.00 V
I have not tested while moving as DVM cables are short and it was dificult to have a proper connection.
Any similar experience or meter readings?
Also when I put the DVM to check the ACV, I got zero reading.
CWA
